Question about Iomega Zip 100MB (31714) External ZIP Drive
Need a driver for macintosh
I have an old Iomega zip drive that I need to connect to my new Mac in order to retrieve some info from old zip disks. Is there a free Macintosh driver download available?
    Problem Solver:
  • 13 Answers
If its a really old zip drive then its SCSI and not usb. It may even be parallel for a pc. To avoid having to deal with drivers or anything like that. You could probably find a cheap external USB zip drive. You dont need drivers for this, only for the older ones.
Also, you might go to an apple store and get some kid to burn a cd from it, if its just a one time thing.
Hope this helps!
Posted on Feb 25, 2009
How to remove manually a zip disk from driver? Iomega Zip 100MB (31714) External ZIP Drive
Hello, 1st what type of system is it ?, 2nd What type of cables do you have for this Drive ?, 3rd what happened to the power adapter ?
4th are you using Windows, What version, or Mac, What version ?
I'm Sorry, but I need more info than you gave me..
Jul 10, 2014 | Iomega Zip 100MB (31714) External ZIP...
Can't get computer to recognize zip drive
Steve, The 1st thing is to install the correct driver for the 100 on the computer you are using. Is it a Mac or PC? What model of computer is it. I have been able to use the Zip100 disks with an older IIGS and some older Macs (Performa and Mac SE) with no problems. I have had no experience with the PCs. The disks formatted as FAT16 or FAT32 can be read by both Mac and PC. Those formatted for the PC can also be read by Macs if PC Exchange is installed. Mac disks cannot be read by a PC.
Write back with more info to clarify your exact situation.
Ron
Apr 12, 2014 | Iomega ZIP 100 MB SCSI (10011) External...
My Z100atapi Zip drive is recognized by Windows 7, but the old disks are not in a recognized file format. I need to get the old data ..
Greetings - According to Iomega your 100 MB ZIP drive media should be fine at being at least readable (the Iomega software does not work with Win 7) natively by Win 7 and Vista. Since the drive is recognized I suspect the problem is actually the discs themselves.
It turns out that the discs were not very good at long term storage and are notorious enough to have a term referring to the problem as the "Zip Burp" where:
  • A) All files on the disk disappear
  • B) Just Compressed Formats such as JPG, ZIP, CAB, ECT Disapear
  • C) "The Disk Needs To Be Reformatted" message is displayed or
  • D) files disappear as you click them
The only way that I know to find out for sure if your discs are good is if you can find someone with an XP machine that will let you temporarily install your Zip drive (including the latest drivers) and see what happens.
Good Luck,
Mikeywaf
May 27, 2011 | Iomega 100MB IOMega ZIP Drive Internal IDE...
How do I reformat my Iomega eGo hard drive so that it is compatible with my Mac? OSX 10.6.6 The current IOmega format is FAT
First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
  • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 08, 2011 | Iomega 500GB eGo Helium Portable USB 2.0...
HOW TO FORMAT A ZIP DRIVE FOR MACINTOSH SYSTEM 7.6.1. I need to copy data from my old mac's hard drive in order to copy it to a new machine.
Format on your old Macintosh using standard Mac HFS, then your new Mac will read the files without problems. Reformat the discs if they came pre-formatted for DOS as the filenames won't copy properly and will be very slow to read/write If your new Mac is FireWire/USB only, then you'll need to track down a USB Zip drive (the 100Mg or 250meg versions will read your discs ok.)
Dec 23, 2009 | Iomega ZIP 100 MB SCSI (10011) External...
Unable to see data on Zip Disks
You are saying that you used zip drive in 1998. i want to tell you that in 1998 the processors were of old versions.therefore,you need to install windows 95,only then you will be able to retrieve your data.
As the only reason to be found is that you used win 95 in 1998,now you are using win xp,the files you stored on your drive were only supported by win 95,hence you need to install win 95.
THANK YOU. hope you get a well experience on www.fixya.com
Oct 10, 2009 | Iomega Zip 100MB (31714) External ZIP...
Need driver for PC for Iomega external drive
Try here
http://www.softwarepatch.com/utilities/iomega-zip.html
Jan 14, 2009 | Iomega (11113) Internal ZIP Drive
Iomega Zip 750 Drive
Today I try to use my Iomega 750 USB drive and found it has died. There is no light on the drive and I cannot extract the disc out which is within it. How do I get the disc out and is it worth attempting a Fix. Deperately need some help.
Jul 03, 2008 | Iomega (32453) External ZIP Drive
Iomega zip 100 external
hi
can you try reformatting that? it may readily upgrade itslef after reformatting it.
Jan 28, 2008 | Iomega ZIP 100 MB SCSI (10011) External...
Iomega Zip 100MB (31714) External ZIP Drive Logo
215 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
