Question about Bernina Sewing Machines
I have an older 1998 portable Bernina with feeder problems.
The control knob for the drop feed won't move the machine won't move the material forward when I sew. I opened the bottom and oiled all the parts between the knob and the feeder plate. I tried to move the bullet shaped part back and forth which is very difficult to move. The "U" shaped part that wraps around it will move back and forth. Is there anyway I can fix it myself and if so how? Many thanks for your time.
    Problem Solver:
  • 6 Answers
Maybe just working that bullet shaped part will get it going. If it's a 930, you need to turn the handwheel to make the dogs get back into 'operational mode' after you move the knob.
Sometimes the mechanism is stuck behind the knob. Don't force the knob. It's possible to take the motor casing off and work it loose. Use TriFlow lubricant (small black bottle Sherwin-Williams) and leave for a while. Push gently with a pencil. Whatever you do, don't whack it with a hammer, like some folks say. It likely needs to move in the other direction (if it's stuck in 'regular' mode) i.e. towards the needle end.
Posted on Jan 18, 2009
I have an older Bernina 910 that sews beautifully. However, I have not been able to move the f Ed dogs knob to lower the feed dogs. Any suggestions?
Yep. These older machines are great but they do love to be treated regularly to cleaning and oiling. Feed dogs are often one of the first to fail due to old oil. Then the stitch selectors will stop working, the handwheel may get stiff, and the needlebar will freeze.
Wheel on right side that controls the needle up and down is very tight...
Aug 31, 2017 | Bernina Sewing Machines
I have a bernina 730 and it does a fabulous straight stitch but it won't do zig zag or any ornamental stitches
Assuming this is the older mechanical Bernina 730 Record (not the new computerized model)...Sounds like your machine is seized due to dried oil.
Jan 09, 2017 | Bernina Sewing Machines
Why has the bottom feed dropped on my bernina 1011it dosent move the material when sewing
check the position of the forward /reverse lever/ knob
in the middle will not move the material in either direction
Dec 17, 2016 | Bernina Sewing Machines
My feed dogs all of a sudden will not feed the material through. How can I fix it?
Please provide specific information regarding your Bernina model. The older "mechanicals" do require frequent oiling--not just at the hook, but throughout the machine. (When they made these old machines, they didn't really consider that the machines would still be going strong 20, 30, or even 50 years later.) Could be the oil surrounding the feed dogs has dried and is preventing the parts from moving.
2 527 Search results for Bernina oil sewing machine
If your Bernina is a newer computerized model, you should probably take it for service.
NOTE: The mechanical machines use a different oil than the computerized models. Be sure to get the correct oil for your machine.
Jul 14, 2016 | Bernina Sewing Machines
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
How do I lower and raise dogs on the bernina 1008
unless there is a mechanical failure , the feed dogs are governed by the forward/reverse control
if it is in neutral position then the dogs will not move
Oct 27, 2015 | Bernina Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
I have a bernina sport 801 and the fabri feeder
There is a small knob on the lower part of the main body under the stitch length lever. This controls the feed dog up or down. Make sure that it turns easily and fully to both positions. If it does and your problem persists, the feed dog height adjusting point is probably loose. A knowledgeable repair person needs to look at it. It is not a difficult repair, but several approaches need to be taken.
Jan 09, 2010 | Sewing Machines
Sewing Machines Logo
158 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
