Question about Radio Shack Televison & Video
Need code for vizio tv for radio shack 15-2133 remote
I have downloaded the manual and it doesn't have a code for the 15-2133 remote for a vizio tv.
Nitrotrike
  • 589 Answers
SOURCE: radio shack 3 in 1 remote 15-2147
Here is the user guide:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502147_PM_EN.pdf
Posted on Jan 10, 2008
robotek
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
SOURCE: Need codes to use radio shack hdtv remote 15-135
can not program my control can send me a tutorial or what's in store radio shack
Posted on Jan 03, 2010
  • 76 Answers
SOURCE: Need code for olevia tv with radio shack remote
call radio Shack or Google the company who makes the tv.
Posted on Mar 18, 2010
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
How do I get my radio shack remote cat. no. 15-302 to work with my vizio tv? I don't have the manual any longer.
Kyle-
Here are direct links to all the information you need for programming your remote to work with your Vizio TV. Click the link and the file will open. From there you can view, save and/or print the files.
Quick Start Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_QS_EN.pdf
User Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_PM_EN.pdf
Code List:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_AD_EN.pdf
The codes for Vizio TVs are: 109, 115, 139, 343, 450
Please rate this solution if you find it helpful. Thanks.
Oct 17, 2010 | Televison & Video
Can't program for tv need sanyo tv codes
This should take you to where you can download the owners manual for your remote. It is a pdf zip fileRC Files: Miscellaneous - Radio Shack 15-2147 "3-in-1 Easy-to-Use" Universal Remote by
Sep 25, 2010 | Radio Shack (15-2147) Remote Control
I HAVE A RADIO SHACK REMOTE 15-2147
need code for toshiba
and how to program the remote
Sep 11, 2009 | Radio Shack (15-2147) Remote Control
Need code for vizio plasma 50" tv, help please. also for a magnav
Ok, try using the guide, there you will see the code, If not then try calling or going to the store that you purchased your item.
Jan 11, 2009 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
74 people viewed this question
Top Radio Shack Televison & Video Experts
xxxxxx xxx
S. Gontko
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
