How can i connect to internet?
I can not connect to the internet due to its configuration
  • 27,725 Answers
You will need to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc or you might download one if you dont have on a disk Make sure you Ethernet is enabled in bios Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection Hope it helps.
Posted on Jan 01, 2013
Google Chrome's connection attempt to www.facebook.com was rejected. The website may be down, or your network may not be properly configured.
Such type of problems mostly occurs due to slow internet connection. I would suggest you to optimize internet. Also try to update the drivers that control your PC and scan your PC with an updated Anti-Virus.
I would suggest to use PC optimizer tool like PCfresher that will not only fix windows internal errors but will also optimize internet.
Feb 11, 2013 | Google Chrome
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I dont know how to get wireless internet
Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring.
When done, log in to the web interface of your router device and check if it can obtain the IP address from your ISP or not.
If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
You may also need to configure the default gateway settings also. To configure your router device as the default gateway, reboot your PC. When done, open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
If you are still unable to browse the Internet, ping your router's connection to the PC.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
When done, check back if you can browse the Internet or not.
***If you need any kind of technical assistance you can contact support cell
Jan 21, 2013 | Computers & Internet
Last night my motherboard burnt due to powersurge from the ISP provider switch. they are not believing that the power surge is from the switch, anyway. i have cable internet connection of 10mbps i dont...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 12, 2011 | D-Link (DI-784) Wireless Router
We have very slow internet allways, we are using wi fi wich is unlock and everytime where inded in very slow connection,how we will secure our wi fi connection?
set the password in your Router. then it will be secure.
If you provide me the Product name of router then i will help more.
May 07, 2011 | Computers & Internet
Can't connect to internet due to no configuration settings available from Globe network. Present location - Philippines. Fon was from USA, just unlocked it here in the Philippines.
Your Motorola CLIQ MB 200 has an Android OS. Here's how to configure the internet on your phone:
Go to 'Menu'. Choose 'Settings'. Choose Wireless & networks Select Mobile networks. Go to Access Point Names. Press the Menu button. Tap New APN.
Supply the following settings for Globe Telecom:
Name: GLOBE (or anything you want) APN: http.globe.com.ph LEAVE THE REST OF THE FIELDS AS-IS
I hope this would solve your internet connection problem.
Mar 16, 2011 | Motorola Mobility CLIQ MB200 Mirror...
After installing the update i cant get online due to error console. Unable to scan for network due to undetectabilility.
Please clarify your problem.
Try resetting your modem and internet connections:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now....
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Nov 03, 2009 | Acer Aspire™ T180 PC Desktop
Tried to secure my wireless connection, but all I did was stop my UTStarcom adapter from getting internet access. I now can't log onto my UTStarcom router setup page anymore. Can't I just reset this? I can...
Symptom You are trying to access the Belkin router’s Web based Configuration page and you are not able to do so. You can access the Configuration page from any computer behind the router.
Resolution To address this issue, follow the instructions below:
  1. First check for the physical connections between the computer and the router. There should be a cable (cat5 or above) running from one of the LAN port of the router to the Ethernet card in the computer.
  2. If the computer is wireless, it should be associated to the Router/AP.
  3. Check for any firewalls (Mcafee, Norton Internet Security) on the computer, which should be disabled.
  4. Check for an IP Address on the computer in the range of the router i.e. 192.168.2.x (x can range from 2 to 254). The router also assigns an automatic IP address to the computers in the range 192.168.2.x (x can range from 2 to 100). For instructions on how to check the IP address on the computer, Refer to Article 13.
  5. If you are not getting an IP Address on the computer from the router you will need to manually assign an IP Address to the computer.
  6. You also need to restore the Internet Explorer browser to its default settings.
  7. Go to Control Panel and click Internet options. Select the Program Tab and click on Reset Web Settings.
You should be able to get the router's configuration page if the above instructions are followed in order.
Cause You not being able to logon to the router's configuration page could be due to the following reasons:
  1. The computer is not able to establish connectivity with the router (wired or wireless). This can happen due to physical reasons E.g.: Improper cabling, bad cable, and no wireless signals.
  2. The computer not getting an automatic IP address from the router (DHCP ** assigned).
  3. Firewalls (Mcafee, Norton Internet Security) on the computer blocking the communication between the computer and the router.
  4. Improper browser settings (Internet Explorer)
** Dynamic Host Configuration Protocol
Summary The Router is a configurable device and you can manually log into the router’s configuration page to set its various operating parameters like connection type, security features and options to update the router’s firmware.
Jun 22, 2009 | Belkin (F5D7231-4) Wireless Router
Netscaping
Yes, Netscape 6.2 will work properly with the web page-based interface used in D-Link DSL routers, however, due to problems the browser has loading Java applets and working with Java scripts all of the features may not be visible. Netscape 4.7 does work with the interface, but is extremely slow in loading the various configuration pages. For these reasons, it is recommended to use Microsoft Internet Explorer 5.x or 6.0 to configure D-Link DSL routers. Internet Explorer loads the pages faster and Java applets work properly, as shown below. Note the tree in Fig. 1 (using Internet Explorer), representing the router´s various configuration pages and in Fig. 2, the PPP Connection information. Using Netscape 6.2 as shown in Fig. 3, the configuration tree is missing and in Fig. 4 the PPP Connection Information is not displayed.
Feb 16, 2006 | D-Link DSL 500 (DSL-500) Router
Computers & Internet Logo
David Payne
David Payne
