Novice here and changing a thermostat. Have a Carrier FA4ANF048 system. Changing from an old circular thermostat to a Honeywell RTH7500. First, is this a heat pump system? Wiring is attached differently if it is and (we're renting) not sure if this Carrier system is a heat pump system. Most web material makes me think it is.
  • Danny Clark
    Danny Clark May 11, 2010
    What color wires were on the old thermostat, and what terminals were they attatched to?
    Problem Solver:
  • 12 Answers
Return t-stat for another with o/b terminals
Posted on Jan 21, 2009
How do you change batteries in thermostat RTH7500 series?
Grasp thermostat and pull straight out. Comes off mounting bracket. Here's manual
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1899EF.pdf
Jan 20, 2017 | Heating & Cooling
How to wire Honeywell thermostat RTH7500 from old Weathertron GE
You have a control board on your furnace, there is a 3 amp fuse there, that 3 amp fuse needs to be replaced. You most likely touched a wire even by accident and blew the fuse. You will have to remove the door \panels to get at it. It looks like a normal car fuse
May 31, 2010 | Honeywell Electronic Programmable...
System will not turn off
Call the honeywell technical service number listed on the instruction sheet for the thermostat.
They can verify if you have the correct stat for your application and the wires are connected to the right terminals.
May 30, 2009 | Heating & Cooling
Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
May 10, 2009 | Heating & Cooling
I need to reset the date and year
I had exact same problem with RTH7500. Did not set the date properly at the beginning and than realized that there is no menu option to change the date after it is saved once (???!). I was very confused for few hours and wandering - trying to find changing option on thermostat menu; than I was looking online what can be done... I could not find solution...
Than I took out both AA batteries, open the thermostat (be very careful while doing this - you don't want to break plastic peaces that hold the thing together) and took out the button battery thinking that this will reset the thermostat... but it did not.
I repeated the same thing, but this time, while the button battery was out, I put two AA batteries back and this reset the thermostat... the old - blinking date appeared and I was very happy to see this on thermostat screen! This time I set the time properly and it works fine.
Hope this will be helpful if you did not solve the issue yet... if you did, someone else might find this solution useful.
Mar 01, 2009 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
