Question about Delta 37 658 Set Of 3 Knives For 37 190 And 37 195 Jointers
How do i remove the infeed table on a delta 37-190 planer
3 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: how to change planer blades
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Posted on Dec 03, 2008
  • 12 Answers
SOURCE: delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
Posted on Jan 16, 2010
The infeed roller turns but the outfeed roller stops turning every couple of inches.sometimes doesn't turn at all. Any idea how to fix this?
Parts are no longer available from Delta. It does sound like a stripped or slipping drive gear on the outfeed roller.
Jan 11, 2015 | Delta TP300 Shopmaster 12-Inch Portable...
How do I replace the infeed dolor on a delta 22-260 planer
Most parts bought will come with the installation instructions
Delta 22 560 Type 1 Planer Parts
Cheers
Billy of Hayward
Sep 26, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
Severe sniping with planer
You will always have snipe at the end of planed boards equal to the distance from your infeed and outfeed rollers. It's severity is determined by how much the board sags or dropps behind the planer until the second roller catches the board. Some planers have extended tables to help with this. What you can do is hold the board up as much as possible and still let the infeed roller move the board smoothly until the board contacts the outfeed roller.
Jan 30, 2013 | Craftsman 12 amp 12-1/2" Bench Planer...
Delta tp 305 is sniping wood at both ends , is there a solution to this problem?
With any of these portable planers, the sniping can be a problem that you can minimize. Of course you can use a board longer than you need... but more practically: 1. Take light cuts 2. Make sure your infeed and outfeed tables are at the same height and are parallel to the suface of the machine below the cutter. 3. Provide additional in-feed and out-feed support beyond the little in-feed and out-feed tables to keep your material moving consistently in the same plane from start to finish. you might use support rollers. Take care to get the whole setup adjusted all in one plane. Good luck.
Oct 16, 2012 | Delta TP300 Shopmaster 12-Inch Portable...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
Can I level the infeed and outfeed tables on my 6" Ridgid planer/jointer? I don't see such information in the manual.
The majority of jointers even cheap chinese imports have 3" or 4" hand cranks for both infeed and outfeed adjustments. The gibs can usually be adjusted when needed even on cheap jointer planers.
The rigid website has a support page and product parts and manual download.
If the download doesnt work call them and insist that they e-mail or mail a paper copy.
Most jointer planers are somewhat similiar in design and appearance.
Some power tool instruction manuals from competitors may have more complete step by step instructions.
Jan 20, 2011 | Ridgid Masonry Tools
How do you make the outfeed and infeed tables paralell? The infeed table closest to the blade is a little lower than the other end? Any suggestions?
Instruction manual is here.
Exploded diagram is here.
I'm pretty sure you're saying your planer tables are not coplanar.
http://thewoodwhisperer.com/jointer-setup/ is worth watching. Despite his comments about a level, a decent level works fine for making sure your tables are flat and coplanar on smaller units like this.
On more expensive planers there are gibs that can be adjusted to fix this issue. Your part list doesn't list any gibs, so it looks like you will have to loosen the screws holding the infeed or outfeed table in place and shim it. You can use a metal feeler gauge to figure out how much need to shim it.
Also, if you're still in warranty, Delta may be able to replace your unit. If you're going down this route, I'd recommend you take a level and your unit into a service center so you can show them the problem.
Be aware that the replacement "could" be worse than the original. Be sure to check it. I recently waited 6 weeks for a replacement fence for my jointer (mine developed a twist) and the new one had a 3/8" bow in that was ridiculous.
Unfortunately the Shopmaster line wasn't Delta's greatest and there have been a lot of problems with them. It might be worth keeping an eye on craigslist in your area, as decent prices can be had on jointers fairly regularly.
Please vote if this answer was useful.
Jun 10, 2010 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Infeed Table leveling
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Feb 28, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Delta 37 658 Set Of 3 Knives For 37 190 And 37 195 Jointers Logo
57 people viewed this question
Top Delta Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
