Only one wheel rotates
One of the shredder wheels is rotating and the other is not. It makes a clunking noise. wheel won't rotates and make it noise as clunk . paper won't go thru at all. Need it to be repair or replace it. it is dm8c fellowees shedders . office or home
I changed my mind and rid of shedder machine and bought new one. I don't want to bother to repair it.
Thank you for suggest me about ur problem fix up ..
Posted on Jan 19, 2009
Rear wheel clunking noise and squeeling noise sometimes
This sounds like it could either be brakes or a wheel bearing going bad. You can check this by removing the rear wheel and inspecting the brakes making sure the caliper is mounted on tightly and brake rotor isn't showing uneven wear. Also be sure to check the brake pads to make sure that they are not worn down to the squealer tabs. Most new pads are roughly 3/8" -1/2"thick. and will start squealing if at about 1/8"-1/16" thick. If everything checks out fine then check the wheel bearing by simply jacking the wheel up off the ground and grabbing. Now try to move it side to side or up and down, it should have no play what so ever. And spin the wheel to listen for screeching or squealing, it should rotate smoothly with no abnormal noises.
Apr 17, 2014 | 2005 Renault Laguna 1.8
Clunk noise in front end
Do you have 4 wheel drive ? If you do you "could " have a problem with the transfer case. The noise you describe is indicative of transfer case issues.
Apr 13, 2014 | 2005 Dodge Ram 3500
1993 subaru loyale is making a horrible knocking/clunking noise
Hi the only other thing it could really be is the wheel bearing itself, usually in subarus they grind or clunk with wheel movement so if you go faster so does the noise, a garage would be able to tell you strait away as you cant really pull them apart without the right gear. Also check the strut, very unlikely but if a spring is collapesd it wll make a similar noise but wont speed up etc, its also worth noting that a cv can make the noises you describe but it would have to be completly destroyed and quite noticable hope this helps
Apr 10, 2012 | 1993 Subaru Loyale
My 2000 model mazda protege makes a clunk when making sharp turns, accelerating or shifting from 1st to 2nd gear?
Sounds like a bad cv joint. Easy way to check is to raise the front of the vehicle so both front tires are off the ground. Use jack stands under the vehicle and block the rear tires. Start the engine and put the tranny in drive. Let the front wheels rotate while the engine is idling and turn the steering wheel slowly in both directions. Listen for the clunking noise. You may have to speed the engine up a little to make it work.
Jan 12, 2011 | 2000 Mazda Protege
Dear sir yes i ment cv joint & no it does
CLUNK NOISE YOU HEAR IS WORN CV JOINTS.
May 26, 2010 | 2003 Saturn VUE
Sounds like a clunking noise, like the sound you hear when you have a flat tire, Tire isnt flat. turning right on the wheel lessons the sound but stays the same turning left. noise seems to be getting...
its a wheel bearing. .will need to be inspected to determine the correct one. Also tires could also do this if the steel seperated internally. Rotate the suspected tire to see if it follows the tire.
Apr 03, 2010 | 1990 Toyota Pickup
Clunking noise from front when going forwards or backing up..jacked front end up..put car in N..spun both wheels and didn't hear any sound..where else can I check
usually the knocking is the drive bearings, or, the shock absorbers...so , i would check the shockers, if your wheels are rotating normally
Aug 06, 2009 | 1993 Ford Tempo
Driver side wheel makes noise, it gets more rapid as I go faster
There are a few reasons why a wheel will make noise when it's rotating. The most serious would be a bad wheel bearing. I would have the front wheel bearings checked, and if the driver's side needs replacement, I recommend that you have the passenger side replaced as well.
Other less serious causes for a noise at the wheel can be a small stone stuck inside a hub cap or a stone lodged in the tire tread.
Jul 29, 2009 | 2003 Chevrolet TrailBlazer
1995 VW Cabrio intermitant repetitive clunking in the front and u
could be outer or inner cv. or a cv bolt that is loose. jack both wheels up and start the car. put it into a gear and check. take care though. this makes finding annoyances like that easier. use a hose against your ear (like a doctor!) to localise the noise.
Mar 17, 2009 | 2000 Volkswagen Cabrio
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
jasbo
jasbo
