Lg neo plasma mini split flashing ch46 - Heating & Cooling
  • 334 Answers
SOURCE: need to find manual to download for LG 2.5 hp neo
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Posted on Jun 11, 2009
hvac1960
  • 2133 Answers
SOURCE: LG neo plasma air conditioner
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Posted on Jan 04, 2011
SOURCE: Hello! The error code is CH46
WHERE SHOULD THE SUCTION PIPE SENSOR BE
Posted on Apr 11, 2011
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
Posted on May 01, 2011
ftw1952
  • 10319 Answers
SOURCE: Mini Splits flashing "ch" then
CH61 means Condenser coil temp high due to non cleaning of condenser/over charged gas/non condensable gas.
Clean your condenser coil. If still problem rests, due to non condensable gas also there will be high temp. Once remove the gas, flush out the system and vacumize and then do gas charging.
Posted on Jul 11, 2011
I have an LG neo plasma airconditioner and suddenly it turns off after about two minutes and it comes up with a code C5. Can anyone help please
Comms Error: check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Dec 31, 2014 | LG Heating & Cooling
Hello, I purchase an LG dual split minisplit air conditioner. It worked all summer long but now both wall units display a "CH 46" error and do not turn on. Any idea what the problem is and how...
A CH46 error indicates the low side sensor or suction line sensor is defective and not within acceptable parameters. It may be loose or off or simply bad.
Sep 12, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Hi I'm trying to get the air conditioning on but I can't light is flashing on the airconditioning and 12pm is shown in remote control Could u help me to sort this matter out I have three LG neo...
We have the exact same problem with our unit. Can't find solution. Any chance you have found out the cause? We also have 3 units, in 3 different rooms. The air vent's are in our garage.
Apr 07, 2011 | LG LSC121PMA Split System Air Conditioner
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
My air contidioner has ch46 flashing and it does not start, can you please let me know what is the problem .
Suction pipe sensor missing or faulty.. suction pipe is your larger pipe . sensors like little bulb things probably an inch long. make sure its pluged into the board properly and sitting on the pipe in its clip. i dont know exactly were it is on this type of unit but just follow the big pipe. sorry i couldnt help you anymore
Nov 10, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My inside unit has an error code flashing ch46 do you have a list of codes and what they mean.
CH-46.Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 14, 2010 | LG LS240CE Split System Air Conditioner
I changed a light fixture in the washroom and It seems that there was a line in the connection box that also serves the wall air conditioner in the bedroom. After checking all the lamo connections again...
Hello Check the wite connections again with a flashlight and see if a wire end broke or is loose.Check the curcit breaker panel box to see if they are all on.How did you turn off power to work on the lamp?The problem is there ,some units require 220volts power.The unit will use the breaker for protection,Did something short out(sparks) at the fixture?
Aug 31, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG dual split CH 46 display.....
We have an LG Split System with a Remote Touch Screen Control Panel. There is a message flashing "CH46". How do we fix this?
Jul 04, 2009 | LG Art Cool LA181CNW Split System Air...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
