Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
Broken ionizing wires on my ionic comfort purifier
Bubbabear64
  • 2794 Answers
SOURCE: Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Posted on Jul 13, 2008
  • 6 Answers
SOURCE: my ionic breeze quadra GP silent air purifier has no power: stopped working!
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
localwonder
  • 6784 Answers
SOURCE: I have several ionic Breeze air purifiers that have problems
Unfortunately, there are no repair depots that are available for use since Sharp Image has claimed bankruptcy. these product are very unique in design and, the actual repair parts are no longer in stock. the suppliers went under when Sharp filed for bankruptcy.
You may be able to repair the wiring by ordering the identical gauge from you local electrician but, that's about it. most of the hardware is no longer available.
Posted on Jun 18, 2009
jepito
  • 216 Answers
SOURCE: Ionic air cleaner
take out the insert and clean it real good ... there is a leaver on back of the machine move it up and down about 10 times to clean the strands ...... make sure you clean the 3 steel thin metal strips good let it dry before you put it back in to the machine ..... + i have that same machine - i have 2 cats - it gets dirty quick
pss the poping sound is the machine is telling you it is dirty ... static electric charge
Posted on Sep 03, 2009
SOURCE: blinking blue light on ionic breeze s1871
the blue light keeps blinking
Posted on Nov 30, 2009
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
Why is my machine buzzing even after i clean it
Hi iramsdail990,
I work for the Ionic Pro company. Please make sure you are cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Jan 13, 2011 | Ionic Pro TURBO Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
It buzzes loudly every 2 seconds
Hi johanm65,
I work for the Ionic Pro company. Please make sure you are cleaning the ionizing wire too. If that doesn't work, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 10, 2010 | Ionic Pro TURBO Air Purifier
I need an ionization wire for my ioninc breeze quadra air purifier where can I find one?
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Jun 28, 2010 | Sharper Image Ionic Breeze GP SI720 Air...
Broken wire inside of air purifier?? Can this be repaired?
If is a wire inside the filter collector cell.Clip as short as possible and remove wire.That part of the collector plate will cease to function as that is the ionizer wire but u can resume using the rest of the filter as normal at slightly reduced capacity.
Mar 16, 2010 | Sharper Image Ionic Breeze 3.0 Air...
I believe that the motor on my Ionic Breeze unit is broken. Can I replace it??
Ionic breeze units don't have motors. I thought they just moved the air by ionization.
The unit might need to be cleaned. Check you owners manual or the manufacturer for instructions.
Dec 09, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
248 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
