Question about Fujitsu 24C1 Air Conditioner
AR-DL1 REMOTE WONT WORK AFTER CHANGING BATTERIES EVEN AFTER PRESSING ACL BUTTON
3 Suggested Answers
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
Fujitsu remote ar-rac3e won't work?
Hi Pat,
If you have a digital camera ie: cell phone - aim the remote at the camera and press the on/off button on the remote
The remote sends out a digital signal unable to be seen by the human eye - whereas the digital camera will see it
If you do see a small flash coming from the LED of the remote, the receiver board in the air conditioner could be faulty?
Good luck
Feb 14, 2015 | Fujitsu Heating & Cooling
I changed battery and pressed ACL but remote is not working
check the infrared led on the remote by holding the lens of a camera phone to it like taking a picture. press any key on the remote. if the remote is fine you should see the led flash when pressing the keys , if not then the remote would probably be faulty.
if you see the led flash then it would more than likely be the evaporator remote pickup that is faulty and needs to be replaced
Nov 01, 2013 | Sanyo RCS-4MHVPIS4U Wireless Remote...
I need a manual for a remote control unit model AR-DL1
Ok so I know this isn't your exact model but it should have info about your remote for it uses the same remote http://www.master.ca/documents/0Op_ASU18_24_30C1_R1.pdf
Oct 11, 2013 | Computers & Internet
I have a fujitsu ac/heating unit that you can only operate with a remote (model nber AR-FB5) Have changed the batteries, and know that the current ones are good. It still don't work. Any...
before call the service man you need to reset the RC. if the problem persist you need to check if the RC is emitting or not on every electronics expert near tou you. if that ok chek the indoor unit by pushing the manual buton on the right of filters. if the unit is dead you have problem with suply 110V or with transformer( 110 to12Vdc) or with the main PCboard. FUJITSU GENERAL AMERICA, INC.icon_telephone.gifTel : +1-973-575-0380icon_fax.gifFax : +1-973-575-2194Address :
353 Route 46 West
Fairfield, NJ 07004
U.S.A.
Feb 21, 2011 | Heating & Cooling
Hi.... My Air conditioning remote control AR-DL1 doesn't seem to be working.It's been working on and off for a while,but now ....Nothing at all ( I changed the batteries also ) .Since I don't know if it's...
Remove batteries and keep for 5 minutes. And also remove DC wire plugged in display sensor in your indoor unit. Now, plug again DC wire in same position and also put batteries in remote. Power on and try now. In many units, this type of resetting would help. If still problem, check remote thr' camera mobile by pressing any button in remote. If ultra light flashes, remote is o.k.You have to repair/replace PCB only. If no ultra light, replace remote.Thanks.
Feb 01, 2011 | Heating & Cooling
My buttons on my 2005 honda accord 4 cylinder car wont work
I assume this is the only remote you have? If not does the other have the same result? Have you changed the battery in the remote? If yes, is it installed with the right polarization?
Feb 28, 2009 | Vehicle Parts & Accessories
Jan 23, 2009 | Fujitsu 24C1 Air Conditioner
Wall Hung A/C unit remote control # AR-DL10 batteries died last. Replaced remote batteries with 4 new duracell batteries. Unit came back on but running to warm. I tried to figure out the programming of the...
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Cheers,
Garry Rogers (ausgaz)
Dec 16, 2008 | Fujitsu 18C1 Air Conditioner
Air Conditioner Model @AR-DL10
Open the slide cover and pull the batteries out. Next press the ACL button on the remote and make sure the ABCD slide is on A
Aug 04, 2008 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
76 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
