Question about Garden
My clarke pls 190 pressure washer wont start, i have renewed spark plug, checked oil level, etc
  • 313 Answers
SOURCE: pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Posted on Jun 08, 2008
  • 104 Answers
SOURCE: oil dipstick and red twist knob on top of the two pressure gauges
the big red knob adjusts working pressure to hose- refer to book or dowload online
Posted on Dec 17, 2008
rselvy
  • 83 Answers
SOURCE: 2001 Kawasaki vulcan 800
The two switches you are having problems with are thermetically controlled; they can easily short out which will cause the light to stay on. First what I'd like you to do is disconnect them at the sending unit, if the lights still stay on you have a short somewhere deeper in the wiring. Most likely it will be a grounded wire. If the lights do go off you will then want to use an OHM meter to check continuity at the senders. If you get solid resistance then the sending unit is shorted out, if one remains open then isolate the other. You may have a situation that one switch is causing both to stay lit.
Let me know if this helps you out at all. Tell me if you don't have the resources to co the diagnostics as described and I'll be happy to give you a work around. We will just have to be a little creative.
Either way let me know and I'll be happy to help you resolve the issue. I'm inclined to thing your problem is a short not a heat related issue since both sending units are both indicating a problem.
Regards,
RSelvy
Posted on Jan 15, 2009
  • 211 Answers
SOURCE: wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: wont start
tip a cap full of fuel in top of the carb to start intitially, check for spark as common fault is on/off switch, If no spark, link the 2 wires on on/off switch together.
Posted on Apr 01, 2009
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
1992 celica wont start and now battery is dead
Engine starting depend on the following systems:
1. Fuel system (fuel level, fuel filter, fuel pump pressure etc).
2. Ignition system.(Ignition fuse, spark plugs, spark plug cords, distributor signal, ignition coil, and ignition switch)
3. Battery. (11.4 V - 14 V)
4. Cylinder compression. (145 psi - 190 psi, valve clearance)
5. Starter rpm (250 rpm)
Sep 16, 2013 | 1992 Toyota Celica
Pressure washer hard to pull string
Unless your unit is equipped with an easy start feature...and I think these are not, it is not usual to have to pull the trigger on the water gun to start one of these units. Also...if there is any chance that the washer has tipped over, there is a possibility that oil has gotten into the engine cylinder. Oil will not compress and the rope cannot be pulled..at all. Remove the spark plug and step back away from the exposed hole. Pull the recoil handle and watch for spraying oil from the spark plug hole. Pull a few more times, clean up the plug and the unit may start. If not, you may have to remove the carb bowl and drain more oil. Check your oil fill level. If your gas level is suddenly low you may have gas in the oil crankcase and need to change your oil. When the washer starts it may blow smoke for some time before it clears up.
Oct 20, 2012 | Karcher 2500 PSI Pressure Washer
The motor wont start
This could be a few different things. 1. Check oil level, if your machine is equipped with a low oil sensor the engine will not start if oil is low. 2. Check the spark plug, remove it and place it against something metal and crank the engine over while looking at the spark plug to see if you have spark. Don't hold the plug because you will get a shock. 3. Check the carburetor, remove and clean. Check the air filter, make sure its clean. If these steps don't work let me know.
Jul 23, 2011 | Black & Decker Garden
Wont start always starts on first try
first check the spark plug,if the tip of the spark plug has oil build up,then replace.
also clean air filter & check oil level.
Oct 05, 2010 | Garden
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
No plug fire
This may not be the only solution but... the engine has a low oil pressure sensor that when the oil is low grounds the spark. Make sure the engine is completely serviced with oil. Once your sure the oil level is full attempt a spark check.
If you still do not have spark start looking at the black wire from the throttle control and check to see there are no bare / exposed parts on the wire that are touching the engine some where.
If all of that looks fine then disconnect ONE lead from the low oil level sensor and check spark again.
If you still do not have spark then most likely the problem can be either the igniton module or inside the air shroud a ground on the ignition coil or..... a failed coil.
Also make sure that the plug wire is not chaffed where it passes through the air shroud.
Thanks for using FixYa,
Kelly
Jun 23, 2010 | Briggs & Stratton Gas Pressure Washer...
List items for service at 5 year service interval
Maintenance must be carried out at 16 000 km (10 000 miles) or 12-monthly intervals from date of delivery, whichever comes first.
Renew engine oil and oil filter.
Renew drain plug sealing washer.
Renew drain plug assembly.
Visually check underbonnet/underbody
for any fluid leaks.
Inspect brake pads for wear (brake disc
condition on pad change).
Renew coolant.
Renew spark plugs (Normally Aspirated). 112 000 km (70 000 miles)
Renew spark plugs (leaded fuel markets only).
Check accessory drive belt tension wear indicator(s) – replace belt(s) if necessary.
Renew front accessory drive belt. 160 000 km (100 000 miles)
Renew rear accessory drive belt. 112 000 km (70 000 miles)
Check/top-up brake fluid level.
Check/top-up coolant level.
Check/top-up windshield washer reservoir.
Check/top-up power steering fluid level.
Check/top-up battery electrolyte level.
Apr 29, 2010 | 2004 Jaguar X-Type
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
