Question about Smith Corona Sears Sr1000 Electric Type C Typewriter
Bought a new ribbon and correction tape.
When I put on the ribbon and correction tape, nothing shows on the page. The keys are not hitting the ribbon?
4 Suggested Answers
SOURCE: how to install correction tape and what one to buy?
Where can I locate instruction on how to install the correction ribbon on a Smith Corona electric typewriter?
Posted on Jul 06, 2009
  • 86 Answers
SOURCE: How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Posted on Nov 11, 2011
  • 3594 Answers
SOURCE: I bought a smith corona SD770 at a garage sale I have found correction tape for it BUT when I set it on the spolls and put the ribbon cartridge back on and type the correction tape comes up I don't kn
The L/O is a cassette SCM #21060 or General Ribbon T369. The ribbon is a (H) series SCM # 21060 or G. R. T309C.
DickyO
Posted on Nov 14, 2011
I have used Code key by mistake and cannot correct.
Remove the print wheel, look for bent spokes and be sure that the ribbon or correction tape are not tangled in it.
DickyO
Feb 25, 2015 | Smith Corona Typewriter SD650 Refurbished...
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Changing correction tape
Go to brother.com, click on support you will find a manual there.
DickyO
Jun 25, 2010 | Brother EM-530 Typewriter
When we type the keys hit above the ribbon.
Sounds like the ribbon isn't lifting try some WD40 on the ribbon motor bearings.
DickyO
Oct 15, 2009 | IBM Wheelwriter 30 Typewriter
Lost manual for Smith Corona sl 575 spell right typewriter
how do I replace the correcting tape in my Smith Corona Spell Write XD6600?
Jan 06, 2009 | Office Equipment & Supplies
Changed correction tape but still won't work
either; 1. you have a non-correctable film ribbon, (it should say correctable film ribbon on the box or the ribbon itself) you can check by taking a piece of scotch tape, hold it next to the letter you want to erase, sticky side towards the paper, and hit the CORR key, CAREFULL YOUR FINGERS AREN'T IN THE WAY. if it corrects, the ribbons ok. 2. make sure the DULL side of the corr. tape is faced toward the paper
Dec 02, 2008 | Brother GX-6750 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
Smith Corona Sears Sr1000 Electric Type C Typewriter Logo
21 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
