Question about Konica Minolta Printer Fax Scanner Copier- 7130
I ned a printer drive for a Konica 7130/IP 422 PCL
Have just upgraded my laptop and can't find the PCL driver for the MDF
  • 3,606 Answers
Hello the driver is available here:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=130&filetypeid=0
Try to install the driver in compatiblity mode if you run a newer system than windows xp.
Or the solution is to buy a new printer.
Good luck
Posted on Jan 02, 2013
  • kgreaney166
    kgreaney166 Jan 07, 2013
    Thanks Hans, I am running Windows 8 and it will not let me down load the driver. Fortunately I do have an other laser I can use.
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
Mar 05, 2010 | Konica Minolta bizhub C250 All-In-One...
May i know where can get the vista printer driver for konica P1350w printer
Konica Minolta has not developed a Vista driver for this printer. Their support stopped with XP.
They have however, developed what they call a Univeral Print Driver (UPD) which will support Vista (both 32 & 64 bit).
Follow this link and download and use
PCL Version 1.0.0.0
Konica Minolta UPD Installer PCL
Nov 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Connected ir3300 to network. Can ping static ip address. the PS3 print driver install detects the printer on the network. Printing fails - print times out every time. Tried installing printer on Server...
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
Aug 17, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Aug 04, 2009 | Konica Minolta Di1610 Copier
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Pcl xl error
Di183 standard m/c with GDI printer,to Print thru PCL driver u need to have Image controller installed in the m/c. So delete the printer driver & install the GDI printer driver.
Mar 13, 2009 | Konica Minolta DiALTA Di183F Copier
Slow printing of large pdfs
Sounds like you are just bogging down the Printer's memory.
Your best option is to upgrade the memory.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA 7145 PRINT DRIVER
The Konica Minolta 7145 have two different companies that made the print controller. If you have an older KM 7145 then you need the old Peerless Legacy driver. It's not on KonicaMinolta's website. You can use HP 5Si driver, but you won't have and of the options (ie finisher, fax, lcc).
Mar 14, 2008 | Computers & Internet
Konica Minolta Printer Fax Scanner Copier- 7130 Logo
451 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
