Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Chainsaw wont start
There isnt any spark when operated against the cylinder head
  • Anonymous May 04, 2009
    No spark at the plug. Ran fine when I put it away.
  • 3 Answers
The ignition coil may be bad or a short from the wires connecting to the ignition coil.
Posted on Feb 27, 2009
I have a gardentec 52cc chainsaw which wont start. I have a spark and fuel getting thro.
Hi you mentioned that you defo getting spark is that from spark plug against side of engine, try this put a very small amount 50/50 pet oil inside cylinder head through sparky entrance screw spark plug back in try it now if it pops abit no matter after 5 times you have a carb prob float faulty jets blocked, blocked feed line, Advise you need a bowl petrol no smoking wash carb in it blow clean jets put back only when all is clean check petrol tube sometimes they go hard and block up make sure petrol is getting to cylinder head, hopes this helps
Feb 17, 2014 | Garden
029 stihl wont start
Disconnect the stop switch to rule out a problem here, if there is still no spark with the plug out and earthed against the cylinder, then it sounds like a replacment ignition unit is required
Nov 25, 2012 | Stihl Garden
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
Husqvarna 162 se wont start. No spark
Check the ingition module and gap between the module and flywheel. use a 0.25 feeler guage
Dec 29, 2011 | Husqvarna Garden
325hd 60 hedge trimmer. Sparks but wont start. It has fuel, maybe flooding slightly? When pulled and pulled can just get it to fire slightly but never start. Has become a pain. Could this be electrical...
The ht leed runs very close to the cylinder, they can chaff through and spark against the cylinder, remove the top cover and pull the leed away from the cylinder and try again, the engine on this machine runs very cool, they are quite prone to carboning the rings in, once they lose an amount of compression they become very erratic and difficult to start, they really do not suffer with anthing else.
Aug 22, 2011 | Husqvarna Garden
The moter just cut out completely
check your spark plug first
#2check your plug wire,, it will ground out against the cylinder and sometimes the spark plug wire will come out of the coil and you wont be able to tell unless you take the pull start off and if you still have no spark the coil is shot
Mar 30, 2011 | Garden
Got spark starting fluid wont turn it over
Check to make sure you have compression in the cylinder, place you thumb over the empty spark plug hole and pull the cord, if it blows hard against your thumb then it has good compression, if it has spark and compression it will start unless it is not getting fuel. Be careful when using starting fluid as to much of it can damage the engine. If there is no pressure against your thumb then there is a copression problem where the piston rings maybe bad or something is stuck open in the intake or exhaust.
Mar 17, 2011 | Garden
Getting to much gas in the cylinder . wont start
Flush out the cylinder by running it with choke off, leave for 5 minutes then try to start again with choke on.
Check that the air filter isn't dirty as this can cause too much fuel to be sucked in through the carburettor.
Ensure that you have a spark by removing plug and holding body of plug against the metal of chainsaw body while pulling starter rope. This can be awkward and possibly risky. Ideally you should do this with fuel removed from the tank and allow the gas to evaporate from the cylinder. You also have to think of how to keep the spark plug against the chainsaw as it will bounce about while pulling the cord.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Wont start spark plug is wet . has good compresion
Possibly magneto problem.
Remove sparkplug and whilst wearing a thick rubber glove hold side of plug against engine head. Pull start cord and watch to see if there is any spark. If not replace spark plug first. If that doesn't solve it replace magneto. If there is a spark then the plug may need cleaning and the gap may need adjusting, fuel mixture may be too rich
Feb 18, 2011 | Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
211 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
