Question about Home
Mirolin jacuzzi tub pump wont start - Home
5 Suggested Answers
SOURCE: Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
Posted on May 20, 2009
uspartscente
  • 717 Answers
SOURCE: I don't see any start
Fill the tub with water. get it in. touch the Logo.
Posted on Feb 01, 2011
  • 55 Answers
SOURCE: I have a kohler jacuzzi
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Posted on Feb 20, 2011
uspartscente
  • 717 Answers
SOURCE: I have a jacuzzi tub
Surging is caused when the pump doesn't have enough water to push to the jets. this is usually a problem caused by air being drawn into the suction of the pump.
take a look at the jet(s) facing the suction cover.
I have seen cases where the water with the air mixed in causing bubbles gets sucked into the suction of the tub and causes the surging because the pump is pulling in too much air.
try rotating the nozzle of the jet facing the suction away from it. point it another way. turn the air control knob closed and see if that is the problem.
the only other issue that could cause this 'surging' problem is a leak in the suction line and could be the source of the water you see under the tub.
Posted on Aug 18, 2011
Mirolin jaccuzzi air tub
If your pump will not shut off then the Air Switch in the motor is most likely the problem with the pump not turning on.
Rod
US Parts Center
Dec 02, 2013 | Home
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Feb 22, 2013 | Jacuzzi Home
I have a Mirolin whirpool for 2 years now . Warranty expired just a few months ago. Happened twice this week where after your finished bath there is an automatic blower turn on after 20 minutes where...
Mirolin warranty is horrible. Immediately after install the tub leaked because of a defect in the tub's drain hole. Mirolin won't cover any damages caused. Had to pull our whole ceiling below and replace flooring.
Apr 05, 2012 | Whirlpool Home
Jacuzzi hot tub pump. Put new pump and motor in water wont circulate but can here pump running.
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Nov 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Apr 05, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
