Question about Garden
How to drain hydraulic reservoir john deere 5575
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
I have a John Deere 5103 the hydraulics are jerky started out a little now its bad loader steering etc. Is it the pump or filters
indicates inconsistent pressure
low fluid level in reservoir, blocked filters or faulty valve system can cause the problem
Oct 28, 2017 | John Deere Garden
Hydraulics 3130 john deere
hydraulic pump not working
filter to the pump blocked
valve stuck open
Sep 06, 2016 | John Deere Garden
Where are the transmission drain plugs on a john deere 2020 tractor
It is located on the bottom of the transmission reservoir, and that is 1 foot to the right from the battery.
Oct 21, 2013 | John Deere Seat 4210 4310 4410 4510 4610...
Iv'e got a h120 john deere loader the bucket quit lifting it tilts etc.bad cylinders or what?
check the control valve for the lift operation. If it tilts then the hydraulic pump should be ok but if it is not lifting then then the pressure is not getting to the cylinders to push on the rams. Is there enough oil in the reservoir for the operation.
Jun 10, 2013 | John Deere Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
I just purchased a 2440 john deere tractor it was outside for some time so there was H2O in the hydraulic fluid. I changed fluid but I get very little movement from the tractor when I release the clutch. I...
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
