Question about Zephyr Pyramid ZPY-E30 Kitchen Hood
Can find the halogen replacement bulb for my pyramid zephir
I live in Montreal Quebec Canada.
Bulbs are Philips halogena 45w flood
I am not able to find the replacement bulb.
Can you recomend a place where hey sell those?
You can purchase directly from Zephyr through their website, www.zephyronline.com
Posted on Feb 10, 2009
How do I find a postal code for 375 chemin de la Pointe Sud in Ile des Soeurs, Quebec?
Canada Post Website and often phone books have a postal code slistig for the city of the phone book.
Oct 04, 2014 | Computers & Internet
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
I want to know what is the telephone country code of montreal
The country code for Canada is +1 and Montreal Quebec is 514 or as of 2006 a second area code +1 438
So +1 514 or +1 438
Apr 22, 2011 | Computers & Internet
Removed the switch plate and connected the two wires going into the dimmer box and the lights still dont come on. I as thikning by bypassing the dimmer the lights should still function. What else could be...
I am going to stick my neck out a little with this one although I agree with BoomerP. The clue of halogen bulbs is feeding my answer. Halogen bulbs require a high voltage transformer to operate and won't normally work with a dimmer but I never tried it. Bypassing the switch should bring them on though. If you have the proper voltage at the switch and they don't work with the switch bypassed, its probably a bad transformer in the fixture. Good Luck. Be careful.
Feb 04, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
Where can I buy Sylvania low beam bulbs H11B for 2009 Elantra
Hi don..
According to positive reviews (for the seller), these one leads Sylvania 9006 SU SilverStar Ultra Halogen Headlight Bulb Low Beam Pack of 2 (+affordable price)
I hope it was helpful.
Enjoy
Nov 27, 2009 | 2009 Hyundai Elantra
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
Jul 30, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Steamer leaking
I think you have to replace the gasket in the steam valve.
Here are info to Saeco Canada.
Saeco Canada Ltée
8145 Boul. St. Laurent
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
E-mail: info@saeco.ca
Visit the Web: www.saeco.ca
Jul 28, 2008 | Saeco Odea Go
REPLACEMENT PARTS
heres the address and phone numbers to contact them
5 Cherry Blossom Rd. Unit 3
Cambridge ON, N3H 4R7
Phone: 519-653-9980
Fax: 519-653-1805
Toll Free: 1-866-764-0468
probably tech support could help you to find a parts distributor.
Mar 19, 2008 | Hussmann Commercial Freezer DCCG-8-D
Zephyr Pyramid ZPY-E30 Kitchen Hood Logo
342 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
