Question about Philips 42PF9431D/37 TV
Television turns on and immediately turns off
When television is turned on, after a moment or two the red light turns on .and television turns off
It costs $2.50 to fix its 2 capacitors in the motherboard need to change them very easy i just fixed mine took me an hour all together and less then 3 bucks .if you open the tv look in the middle motherboard and you will see witch capacitors are blown because the top of them is raised up change them and ure done,all the capacitors have a cross scored in the top ,so they dont blowup ,so if you see 1 raised just a little bit its fried change it while ure in there , they wanted $400 to $500 to fix lmao now .
Posted on Apr 24, 2009
Pressed power, heard the unit turn on, heard the tv show sound for a moment then it went into standby mode and the red light flashes six times, then pauses, six times then pauses, over and over and over. ...
Either your power supply is bad and needs replaced, or their is other circuitry issues. Bets to have a trained technician look at this and give you a quote for repair, it might be cheaper in the long run to replace the set.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
As soon as I turn the power on, it shuts right back off immediately. It will not stay on. Any ideas?
there are leds inside that will light up @ the moment of shutdown.. one on the power supply lights up with ANY shutdown, but at the exact moment (like when you try to turn on from cold) of shutdown, another will light for a split second. depending on where this other red led is, will tell you which board is bad. I just spend like 10 hours working on a 510hd model so I know it like the back of my hand, let me know if you want to dive in. These tvs are notorious for having bad solder connections all over several board and can be fixed easily by a savvy tech with a solder iron. Let me know
Jul 12, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Television turns off
There are red leds that light up inside to indicate which board has the defect. The power one always comes on with any shutdown, but usually there will be another red LED that will fire (only at the moment of shutdown) and you have to look while you try to kick it on. It will probably be on the convergence board and you will need a new board or to fix up that one. Let me know if I can assist futher.
Jun 12, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Philips 42PF9431D/37 TV Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
