Question about Samsung RB195ABWP (187 cu ft) Bottom Freezer French Door Refrigerator
Condensation in the Samsung fridge # RB195ABWP
Constant condensation into crisper drawers causing yellow water staining down the back of the lt. drawer, and water build up inside the drawer.
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
Posted on Apr 15, 2011
imufo2
  • 3773 Answers
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
  • 2006 Answers
SOURCE: I have a Samsung French door fridge that has a
Access is from the rear, but make sure the vents on the front grill are not clogged also because it does need front to rear air flow.
Your unit has two evaporator coils and two defrost heaters and two defrost thermostats, but uses one defrost timer circuit. So if you don't have trouble with the freezer side, then it should be the defrost heater or defrost thermostat for the refrigerator side of your unit. Which are items 1-2 and 1-4 on the following diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Refrigerator-Parts/Model-RF265AABPXAA/1482/0161000/50033424/00002
Posted on Aug 17, 2011
My lg express cool gr482sf has water forming under the crisper. so far both freezer and refrigerator are working well
water condensation? Usuallya s a result of bad door seals allowing air into the fridge and then the moister condensates and becomes water at the bottom of fridge or drawers
Feb 16, 2015 | LG Refrigerators
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Why is there ice in the bottom of the crisper?
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
There is water inside only the right side crisper from excessive condensation ,no change after adjusting vent on drawer to either low or high. Any suggestions?
Make sure the fridge is not overfilled or the back of it isn't covered (leave at least 2-3" from the wall). It sounds like it's heating up (don't put hot food in the fridge), so you need to remove items that don't need to be there. Make sure that the airway is clear to the crisper as it needs to "breathe" to stop condensation forming.
Mar 02, 2012 | Kenmore Refrigerators
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Water in the crisper drawers, condensation line clogged
if condensation stays in there, it'll freeze up on the evaporator coils. when the defrost cycle goes on, it'll melt but stay in the fridge, only to eventually freeze up again. so, unclog that line. also, check your door seals for leaks. that may be where the warm, moist air is getting in.
Dec 04, 2009 | Admiral Refrigerators
Water build up under crispers the fridge is a maytag & has been moved here recently could it be that the fridge in not level or that the drain for the defrost cycle in possibly plugged please give me...
check door to make sure it is sealing correct warm air might be causing condensation in fridge area or check drain freezer -may be clogged causing water to trickle down thru vent at back wall by fan
Sep 26, 2009 | Maytag Refrigerators
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Samsung RB195ABWP (187 cu ft) Bottom Freezer French Door Refrigerator Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
