Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Paper late jam between sensors D and F laserjet cm6040
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
  • 7 Answers
SOURCE: HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Posted on Jul 08, 2008
SOURCE: HP Laserjet 3050 paper jam
software cd
Posted on Feb 18, 2008
  • 27 Answers
SOURCE: HP LaserJet M3027 indicates paper jam but there isn't a jam.
if you are getting a paper jam message but you can not find paper any where in the printer the first thing that you want to do is clean the pickup roller in the paper tray. the roller is located on the top of the cavity that the paper tray is installed in.
Posted on Jun 21, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
HP Color Laserjet CM6040f MFP
Hello Desmond,
You will find all your answers regarding paper jams on this printer at the following link:
HP Color LaserJet CM6030 and CM6040 MFP Series Jams HP Customer Support
This should help you with this issue.
Good Luck!
Rich Lilja
Aug 02, 2017 | HP Office Equipment & Supplies
HP Color Laserjet CM6040 only prints in black and Cyan no yellow or magenta ?
Have they printed 21,000 pages yet, or 10 reams of paper?
Check in the Printer Settings under Maintenance for clues and run the Tests and Maintenance steps.
HP Color Laserjet CM6040 Google Search
Mar 14, 2017 | HP Office Equipment & Supplies
Error 13.20.00
That is a Paper Eject Jam.
The paper stopped at either the loop sensor (E), the fuser-output sensor (F) or the switchback sensor (G).
E & F are just prior to the paper going into the duplexer. G is a sensor in the duplexer assembly. If the sensors check out ok in diagnostics, then I would suspect worn feed rollers causing a paper late condition.
Apr 04, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Apr 15, 2008 | HP LaserJet 2420 Printer
Feb 20, 2008 | HP LaserJet 2420 Printer
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
1,538 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
