Question about Dryers
Kenmore Elite 110.63032101 Starts when I assist by turning drum while pushing start button, but only runs for 1-2 minutes.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
The motor is weak or has dirty (burned) bushings. Most likely the motor will need replaced.
Posted on Jan 18, 2009
The drum won't turn in my kenmore elite smartheat electric quiet pak 4 dryer
CHECK DOOR SWITCH, CHECK FOR BROKEN BELT? CAN U OPEN IT WHILE ITS ON AND TURN BY HAND AND SEE IF IT STARTS? REMEBER TO PUSH IN DOOR SWITCH BUTTON WHEN TURNING IT
Feb 12, 2015 | Kenmore Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
The drum in my kenmore elite he3 wont turn
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 08, 2012 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Starts with asistance then shuts off.
A centrifugal switch selects the start winding, but the run winding is always selected, according to the wiring diagram.
So, it could be a bad centrifugal switch, or a bad motor. You can test the motor by measuring the resistance between the blue and white-orange wires (the run winding), and between the blue and violet wire (the start winding). Both values should be under 4 ohms.
To continue running, the motor run winding must be OK, the door switch must be closed, the belt switch must be closed, and the thermal fuse must be OK.
All this assumes the electronic controller is OK, but this is the stuff a handy homeowner can check before calling in the big Sears guns.
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
