Question about Weber Genesis Silver B Grill
Starter knob difficult to turn
My starter know is getting harder and harder to turn. The other knobs turn fine. Is there a replacement part I can buy or can I just lubricate it somehow?
  • 1 more comment
  • Tim Grieb Jun 25, 2007
    WD40 didn't work. I also noticed that the knob won't push down like the others. Can I replace just the control or do I have to replace everything?
    Thanks for the help Noggin. I'll get the replacement part from your link.
    Thanks again,
    Tim :)
  • bailey9 Apr 21, 2008
    I have the same starter valve problem on a Genesis. The starter knob is vitually frozen and no longer depresses to turn. WD 40 has had marginal but still unsatisfactory results. The two other valves loosened w/ WD40 and operate smoothly. I see there are 3rd party aftermarket valves offered. Is this a threaded connection that is easily changed?
  • 944 Answers
Best thing to try is a bit of WD40 or similar penetrating oil first, and work the knob a little. Usually this would solve the problem. If not, please ask again and we can try to source spares. Hope this helps :)
Posted on Jun 24, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 25, 2007
    You should just be able to replace the sticky control - if you can remove it yourself then you may be able to see a way to open it up and maybe clean up the problem, although usually these are not designed to be opened.
    If you need a replacement;
    Apparently their customer support is quite good so you should find a solution direct from them - please ask aagin if not as there are other dealers who sell spares as well as whole grills.
    Good luck :)
  • Nigel Ridehalgh
    p.s. if you can remove the offending part and post me a photo I may have some ideas of what you could do yourself, although a replacement is likely to be better.
    If Weber don't help you out then these controls are fairly standard across many manufacturers so we should be able to find you one that works, hopefully that will fit where the old one went without the trouble of modifying anything.
Wolf Commercial Gas Range: turning knob on and off very difficult
easy pull the tap apart and clean it with metho and repack it with gas tap grease and take note how you pull it apart also watch out for the spring in side it
Apr 25, 2010 | Wolf Manufacturing Gas Kitchen Range
The start switch will need to be replaced. The control panel will need to be removed to replace the switch.
Apr 19, 2010 | Frigidaire FER231A Electric Dryer
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
The start knob doesn't engage when pulled. Do I just need to replace the knob assembly? Is it difficult?
Take the knob off and try using pliers to pull the stem. Don't pull any harder than you would with the knob. If it works, you just need a knob. If it still won't engage, you need a timer.
Dec 07, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
How do I know where to light the pilot on my wall heater? I'm not exactly sure where the pilot is. I know where the button is and the pilot knob but do I need to turn the gas on and how far should I turn...
I can try and help. Get a working flash light. If you know where the gas valve is, good I will take you from there. On the gas valve you will find a 1/4" diameter aluminum tube and a 1/16" diameter copper wire both screwed into the valve. Follow the larger of the two tubes toward the heat chamber. The tube will enter inside the chamber and you may have to unscrew a cover to get to the pilot. The tube goes to the pilot assembly. If you have button that snaps when you push it in, that is the pilot starter. Look thru a small viewing port and snap the button. You should see a blue spark. This is where your pilot assembly is.If there is no spark, your sparker is broke. You will have to use a ling match or gas grill starter to light the pilot. OK so if you have good spark, turn the gas valve knob to Off. Now turn it to Pilot and depress the knob into the gas valve. It should go in about 1/2". As you hold the knob in, snap the sparker button a few times and continue to hold the knob in. Look in the little window for a flame. Continue to hold in the knob for about 30 seconds after the flame lights. Now let the knob out and check that the flame is still lit. If it is, turn the knob to the On position. You should be OK from there. If you had to use a match, prior to putting the knob to the on position, replace any screws or plates you had to remove to get to the pilot. Good luck!
Dec 03, 2009 | Williams 3003622 Ceramic Wall Mounted...
Starter Knob broken
go to sears .com,click parts put in your model number(should be inside the dryer door)and get your part.or repair
Apr 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Won't turn on when you pull the knob.
replace the timer it has a bad contact in it
May 19, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Weber Genesis Silver B Grill Logo
899 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
