Question about Lexmark Color JetPrinter 1100 InkJet
Lexmark 1100 not printing the second document
I have reinstalled the drivers, and when I try to print out a second document it does nothing. It is stuck in the print spooler list.
    Novelist:
  • 70 Answers
Have you tried printing without spooling?
Disable the spooling feature to see if this still happens.
Right-click printer then click Properties. On the Advanced tab of the printer Properties windows, Select Print directly to the printer.
Click Apply.
You may notice that printing from an application may be slower; however, the point in doing this is to find out if the spooler is causing the issue by bypassing it completely when printing.
I don't know if you used the CD that comes with the printer or if you downloaded drivers from the Lexmark site but you might want to double check the drivers that you're using with the most current and appropriate drivers for your printer. Also make sure that all cable connections are snug.
Here is the link to download drivers from Lexmark http://downloads.lexmark.com/perl/downloads/downloads.cgi
Hope this helps and thanks for using Fixya.
Please share your experience by rating this solution.
Posted on Mar 29, 2009
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
On trying to print from computer off the internet to Lexmark X5150 all i get is a page of letters and nothing like what i am trying to print. I have uninstalled and reinstalled the printer and tried...
select the part of the page you want to print with your mouse.
then press file -> print
on page range, set it on - selection.
It will print the selected part.
Jul 12, 2008 | Lexmark Office Equipment & Supplies
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
Printer won't print! Holding several documents in
Delete the documents ... delete the printer ... reboot ... reinstall the printer.
There is a possibility you cannot delete the documents and there is a possibility you cannot delete the driver ... if that is the case ... install a second copy of the driver.
May 31, 2010 | Lexmark X1270 All-In-One InkJet Printer
Only prints one page at a time
The driver could be corrupted or it is set to default to one page only.
When you bring up the printer's menu, check the setting for the number of pages; it should default to 'All.'
If you find nothing misset, try reinstalling the software that came with the unit.
If it argues with you because it has detected an existing installation, then remove the Lexmark software through the Control Panel, 'Add or remove programs' function. If you have to go that route, then remove that printer from the 'Printers and faxes' folder, reboot with the printer turned on and if asked for a CD, insert the one that came with your Lexmark.
Jan 14, 2009 | Lexmark X2600 InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Odd behavior when printing
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
Jun 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark Color JetPrinter 1100 InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
