Question about Shure 450 Series II Professional Microphone
Volume is too low on shure 450 series II mic
Tried changing from lo to high impedence but to no avail.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Make certain you are connecting to a microphone level input.
Posted on Jul 27, 2014
SOURCE: Need schematic
http://www.shure.com/stellent/groups/public/@gms_gmi_web_ug/documents/web_resource/us_pro_450_ug.pdf
Posted on Feb 16, 2009
  • 417 Answers
SOURCE: My shure sm48 is registering almost no volume on
Undo the set screw near where the xlr cable would connect. Use needle nose pliers to gently pull out the connector. Check to see if the connections are solid. Some of the sm48 have switches for on and off, so it could be that as well. hope this helps.
Posted on Apr 02, 2010
  • 417 Answers
SOURCE: shure sm58 just started outputting very low volume
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Posted on Apr 15, 2010
  • 611 Answers
SOURCE: Hi, I have a Shure Untdyne
Amphenol -> XLR
Pin 1 -> Pin 1
Pin 4 -> Pin 2
Pin 3 -> Pin 2
Posted on Oct 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: Need a replacement element for
Would the whole mic do? eBay has several of them as cheap as separate elements.
Posted on Mar 01, 2011
Microphone will not hook into computer
What is on each end of the microphone cable in its original form? What's the model of microphone? You need a cable that ultimately (probably need an adapter or two) would have the LO-Z (assuming its a low impedence mic) connector for the microphone on one end and the mini phone plug on the other. If the microphone is low impedance, which most good microphones would be, you will need an impedance matching transformer to convert to high impedance which the computer mic input would expect. That would have a 1/4 inch phone plug output which then needs to be brought down in size to fit the computer mic input. A music store would be your best bet for the required pieces.
Jul 23, 2012 | Samson R31S Microphone
I need detail of ic ne 571 for shure mic wireless
try this site...http://www.datasheetcatalog.com/datasheets_pdf/N/E/5/7/NE571.shtml
Mar 10, 2012 | Shure 450 Series II Professional...
I just bought a Behringer K3000FX amp and it sounds GREAT with my keyboard. However, just bought a Shure SM48S voice mic and it just doesn't come thru the amp with much volumn...have to turn amp
Greetings! Ok, your amp has an XLR (3-prong) Low-Impedance input on Channel 1 for a Mic. All the other inputs are 1/4" High Impedance inputs, which are for instruments and/or other High Impedance items including low quality High Impedance Microphones. The SM48S is a high quality Low Impedance microphone, so if you use it with a 1/4" plug, it will be in a High Impedance channel, and will be very LOW in volume in comparison with everything else. So, you must use an XLR (3 prong) cable from the Mic to the Channel 1 input on your amp. That will do the trick. Good Luck with your new amp and Mic!
Dec 02, 2017 | Behringer Ultratone K3000fx 300w Keyboard...
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Dec 13, 2011 | Shure SM58 Professional Microphone
Hi. I've connected my Shure 55SH to my netbook via XLR to 1/4", then with an adaptor to my 1/8" port. My recordings all have significant fuzz, but the level doesn't change when I adjust my...
Most likely the 1/8" jack's input is LINE level. The microphone works at a higher IMPEDANCE and will have to be boosted to line level in order to have a matching impedance to the input on your netbook. You can use a mixer, a DI box, or microphone pre-amp to match the LINE level of your 1/8" jack. That will give you more control over level with less noise.
Mar 01, 2011 | Shure 55SH Series II Professional...
Need a replacement element for a Shure 444. Can I purchase a Shure 450 series II element?
Mar 01, 2011 | Shure 450 Series II Professional...
I just bought a Fender VF3 electric violin. It
The piezo pickups for violins REQUIRE a high impedance input preamp.
The measured impedance of My wife's violin is on the order of 2 megohms.
It sounds like you are having cable connection problems. If you don't have a preamp right at the vilin, then use a VERY short high impedance instrument cable.
Most of the Focusrite mic preamps I looked at had input impedance around 5K ohms which is unsuitable for the piezo pickups.
Here we use an Autolycus pickup on an acoustical vilin and an X2 wireless system. The transmiter has a very high input impedance and the resulting system sounds like a violin.
Some amps themselves DO have a high input impedance, but many designed for guitars do not. Long cables, especially low impedance ones, load the piezo pickup with capacitance which clobbers the high frequency response.
Nov 12, 2009 | Music
I have removed the push to talk button and replaced it with a volume pot but need a wiring diag. from the element to the pot to the XLR. Also, is it possible to wire this to convert it to high impedance?...
The impedance of these mics is around 180 ohms which means you would probably use a pot around 300 to 600 ohms and with an audio taper.
This is NOT a good plan from an engineering standpoint as adding impedance to the balanced mic can allow electrical noise pickup.
The only way to get high impedance is by use of a transformer or a preamplifier. You DON NOT want to run high impedance lines over any distance as they are more subject to noise pickup.
The transformer should be at the far end of the cable run from the microphone. KEEP the impeedance of the cable from the mic LOW until right before a high impedance input amplifier.
Sep 29, 2009 | Shure 515SBG18X Professional Microphone
I cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
Sep 16, 2009 | Shure SM58 Professional Microphone
Shure 450 Series II Professional Microphone Logo
60 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
