Question about Brother Cassette Correctron Riter Xl-10 Typewriter
What type of ribbon for brothers electric cassette writer XL10
Brothers cassette correction writer XL10, Need ribbon number to order
  • 329 Answers
SOURCE: Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
Posted on Jun 12, 2008
  • 3594 Answers
SOURCE: brother ml 100 can't get it off the correction tape mode
First remove the correction tape, then turn it off and back on and let it do it's reset, if it will now type OK check to be sure you have a dry L/O tape, if it is at all tacky replace it with a dry L/O tape.
Posted on Jan 05, 2009
faxman789
  • 297 Answers
SOURCE: what type of ribbon does the brother em630 type writer take?
Here is a link to the brother website...showing all the supplies:
http://www.brother-usa.com/accessories/Accessories.aspx?Model=EM630&ACASCID=2
Part Number: 7020
Correctable Carbon Ribbon (Black)
Posted on Jan 17, 2009
komguy
  • 2306 Answers
SOURCE: SX 4000 Brother Electric Typewriter
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Posted on Aug 27, 2009
Testimonial: "I tried this & it did not work. But your advice was helpful & timely"
  • 3594 Answers
SOURCE: installing new correction ribbon
Go to brother.com click on support a users manual is available there.
DickyO
Posted on Jan 23, 2010
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
Feb 27, 2013 | Brother SX-4000 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
TYPE WRITER DISPLAYS BUT WONT TYPE ANYTHING
There are many "WONT TYPE ANYTHING" symptoms and reasons, like:
is the ribbon installed? Is it installed correctly? Is the carriage moving?
Some description of your concern would be of great help.
I guess you don't have the User Manual.
Here you'll find the PDF version of the manual.
http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=SX4000
Good luck.
May 11, 2011 | Brother SX-4000 Typewriter
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
I have a smith corona type writer and I need to order a cartridge that also corrects. I use to have one!! I have a regular catridge Type II-A Help!!
Try searching on Ebay..you might be surprised at finding one. Type the number or model of the ribbon you are looking for in the search box.
Hope this helps..
squipps
Sep 11, 2009 | Smith Corona Office Equipment & Supplies
Brothers SX400 - cannot get ribbon threaded so key strikes it
If you bought the correct ribbon for a start, then you do not need to rewind it. It should come already wound round its pulleys, and should not fail due to slippage. there should be supports in the mechanism to keep the ribbon in place.
Assuming you have the correct ribbon (that is the fabric is in its right position), and the cassette casing design is correct, the cassette should sit squarely and correctly to enable your printhead to strike the ribbon when you press your keys.
So, the reason why the casing is sitting about 1/4 inch above the guide may well be because of a wrong casing design. Carefully compare the design of the ribbon cartridge that you have with that of an OEM. YOU MAY FIND a lug or protrusion. If this is the case, I suggest you get a new compatible ribbon cartridge with a good design from a reliable source. www.inkribbonpaper.co.uk is one such source.
Aug 31, 2009 | Brother SX-4000 Typewriter
What type of ribbon does the brother em630 type writer take?
Part Number: 7020
Jan 16, 2009 | Brother EM-630 Typewriter
May 22, 2008 | Brother Office Equipment & Supplies
Brother Cassette Correctron Riter Xl-10 Typewriter Logo
120 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
