Question about SanDisk Sansa e250 MP3 Player
I can't remove songs with WMP
When I plug my Sansa e250 into my computer and sync it with WMP 11 I can only add songs to the player. When I try and remove them, media player says that there are no songs added to the device yet. My computer only recognizes it when it's in MSC mode, and I have the latest firmware. Anybody have any ideas?
  • ssk9139 Jan 13, 2008
    I am having a hard time removing songs from my Sandisk Sansa e250 could it be because i down load songs from another computer and trying to remove them from another computer could that be the problem. I am also having a problem when I turn on my mp3 it comes on but it start to refresh which is very annoying. Please help me anyone thats having the problem please let me know what they had to do to resolve this problem or els i am just going to just have to buy and ipod which i dont thing would give this much problem. Thanks for your help.
    P.S. SSK
  • Anonymous Jun 04, 2008
    Can't see any of the songs on the e250 using WMP 11.
Go to my computer folder and then to you'r player (should appear) open it and you should see the folders
Posted on Jul 12, 2007
You have to first change the USB mode on the player to MTP (as opposed to MSC). Forget using the Windows Media Player (yeah, I know). Go to Explorer, go to drive E or whatever your Sansa is listed as....open it and it will show different types of folders. Go to MUSIC folder. The songs are listed and you can delete, e.g. delete mp3 and keep WMA of the same song, or whatever else you want to delete.
Posted on Jun 29, 2007
SOURCE:
We hooked it up to a usb but we cannot copy music to our mp3 player what do we need to add to our computer to do so we have windows media player and that is what we are trying to download some songs into...
open WMP (windows Media player)... import what songs/albums into WMP. connect your mp3 to you computer. WMP should recognize it if it is a sansa. Highlight what songs you want right click ...add.. to sync list. or you can make a sync list on the right hand side of the screen and drag and drop the songs you want on your mp3 player ... when you have the ones you want click on the sync button and those songs will xfr to the player
Oct 18, 2009 | SanDisk Sansa Clip MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
Aug 29, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
How do I transfer
1. Connect The Player.
2. Open Windows Media Player (WMP) 11 or Higher.
3. It detects the Player.
4. Click the Sync Tab on (WMP)
5. Download The Songs you want and place them in the open area where it says to put them.
6. Then Click the Synchronize Button
7. It then downloads the songs.
8. Click the Disconnect Button on the Right Bottom hand side and Disconnect.
Feb 20, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 2GB won't sync with my WMP 11
did you load the cd so your computer can recognise the mp3?
Feb 10, 2008 | SanDisk Sansa e250 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 doesn't sync fully...
Have you tried to format your device using the windows media player?that will help also..if that doest help you might want to go to the sandisk website to make sure you get the latest firmware upgrade for your device..make sure you format the device inside WMP not through my computer...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
