Question about Zanussi ZWC1300W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
Will complete the washing cycle, drain but not spin. The clothes come out soaked any solutions
The end light is flashing 11 times repeatedly what is the cure
Posted on Aug 28, 2010
    Genius:
  • 1,102 Answers
Is it spinning during spin cycle
your timer may have gone
Posted on Jan 18, 2009
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Washer will not spin goes through all cycles but clothes are left soaked
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 16, 2011 | Frigidaire GLTF2940E Front Load Washer
Clothes are still soaking after cycled final spin! water left in tube
heatman101
Mar 05, 2011 | Kenmore Washing Machines
My neptune front loading washing machine will not spin on the spin cycle. Clothes are soaking wet.
heatman101
Mar 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle is not working. clothes are soaking wet when cycle is finished.
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine gets to the spin cycle and stops. Clothes are soaking in water because it won't drain.
heatman101
Sep 30, 2010 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My zanussi jetsystem washer/dryer 1400 7kg load machine is not draining or spinning. It is unlocking so I can (at the moment anyway) get the load out, but the clothes have not drained or spun, therefore...
your machine require new set of carbon brushes, and it also may need the pump impeler checked to make sure there is nothing stuck in it such as hair pin safety pin or a wire from the under wired bra.....
Dec 04, 2009 | Zanussi ZWF1440 Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Zanussi ZWC1300W Front Load Washer Logo
357 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
