Question about Canon EOS 400D / Rebel XTi Digital Camera
I have a canon rebel xti, I partially blocked the pop-up flash while taking a picture. There is an error message on the screen - flash error 05, turn camera off and on again to clear. It is not working. What can I do?
    Guru:
  • 859 Answers
You can reset all your settings and clear errors by removing the battery pack and also under the camera is an access screw to get to a button battery or two. The type of screw you use a dime or quarter to open. With the battery pack out, remove the button batteries and leave all those out for several minutes and then with the batteries still out, activate the On switch for your camera and leave it in the full on position for 30 seconds. That should drain off all residual power from the circuit board inside. You will have to reset everything, such as your personal settings in Tools and the time and date setting. All of those user set items, but your error message should clear too. If you get the error message again, right away, after reinstalling the batteries and battery pack, then you have damaged the Flash Unit... but I doubt that. Canon makes a good camera and I don't think what you describe would cause that problem.
Regards,
Worldvet
Posted on Jan 21, 2009
Canon EOS Rebel XT Error 05 or BUSY
The Error 05 means the build in flash cannot be raised.
In the moment it should pop up, something was blocking the free movement. Could be caused by the way you were holding the camera. Could be happening, while you were pressing the flash button, or when you are in the basic zone shooting mode, such as portrait, which needs the use of the flash.
Switch the camera off an then on again. Move an eventually cause of the blocking and press the shutter realise button again.
Feb 21, 2014 | Canon Cameras
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
When taking a picture is clicks a couple of times does not take a picture and says error 05
Check if something is blocking the in-built flash to pop up or if it is stuck. If the flash is stuck press the flash pop-up button and try pulling it up simultaneously.
May 02, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Built in flash not popping up
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
May 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 400D / Rebel XTi Digital Camera Logo
607 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
