Question about Samsung DMR77LHS Tall Tub Dishwasher
What does an SE code mean on a Samsung dishwasher M#DMR77xxx
Won't drain
4 Suggested Answers
  • 234 Answers
SOURCE: SE error code on Samsung dishwasher
Here are the error codes from Samsung's website:
Error Codes spacer.gif If your dishwasher is displaying an error code, please refer to your users manual for an explanation. If you don't have your users manual on hand, you can download it from Samsung's Download Center. To go to the Download Center and download the users manual for your dish washer, click here.
Common error codes caused by installation errors are:
  • 5E which indicates a kinked or bent drain hose
  • 4E which indicates that the water supply valve is closed or not fully open
  • LE which indicates a leak.
I hope that this helps!
Posted on Apr 15, 2009
SOURCE: i am recieving an SE
I'm getting the same message too. I turned it off for awhile and I had a technician come out and take a look. My drainage pipes are all clear (SE code can mean that drainage is not working properly). He suggested that I get a "Samsung" tech out to take a look at the circuit board/electrical issue. Want to know the crazy thing? This is my second dishwasher that Samsung replaced....all the same electrical issue.....and just last week someone called me to see if I wanted to buy an extended warranty on it. Hmmmm.....do they know that this a piece of junk? It was an expensive dishwasher too.....doesnt clean any better than my cheap model did and it sure has a lot more problems in this first year than the whole 5 years that I had my other dishwasher. Can you tell im disgruntled?
I would love to hear if there is a simple fix to this SE problem.
Posted on Oct 06, 2010
  • 6 Answers
SOURCE: We have a samsung dmr77xxx dishwasher and it
Most 9E error codes are caused by a sticky float located on the LHS of the dishwasher. You can sometimes do a temporary 'fix' by 'thumping' the left panel inside the dishwasher (towards the bottom).
Posted on Oct 07, 2012
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
How do i fix an SE error code on my Samsung dishwasher
The SE or 5E error code means "Draining Error", which coincides with what you observed. First check the drain hose for an obstruction, especially where it goes into the garbage disposer (and check the garbage disposer port to make sure it is clear too). If that's okay, then you will have to pull the dishwasher out to check the drain pump. Chances are, some foreigh object has gotten into the drain pump, and is blocking or partially blocking the water flow. If everything is OK, then you probably have a bad ECS sensor, and will have to replace it. If most of this is beyond what you want to do, at least check the hose at the garbage disposal end before you call a repairman.
Feb 10, 2015 | Samsung DMT800RHS Dishwasher
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
Se code
You're on the right track - SE error code on a Samsung dishwasher means "drain error". If you can get to it, try removing the drain pump. Chances are there is something in it that is blocking or impeding the impeller, or may be stuck at that end of the drain hose (where the check-valve is located.) Good luck!
Aug 01, 2014 | Samsung Dishwashers
SE display code on a Samsung Dishwasher
The SE (or actually 5E) error code means "drain error". Most often, this is caused by a blocked or clogged drain hose, or something hard getting inside the drain pump that is blocking or impeding the free operation of its impeller. If all that is okay, then you may have a bad ECS sensor.
Jun 17, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
What is an se errer code on a samsung dishwasher
SE (or 5E) means "Drain Error" or "water not draining". Check the drain pump and drain hose for any obstruction, of course, If okay, replace the ECS sensor.
May 19, 2014 | Samsung Dishwashers
Samsung error 5e
May 05, 2014 | Samsung 24 in. DB3710D Dishwasher
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Samsung DMR77LHS Tall Tub Dishwasher Logo
123 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
