Question about Kenmore 98702 Stacked Washer/Dryer
Where is the lint screen on Kenmore stacked dryer model 110.98575120
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
carlsbiz
  • 1124 Answers
SOURCE: free standing kenmore dryer series
Could be the heating eliment..
A way to check it ---
remove the exaust hose..
Put a mirror to the exaust hole trying to see inside to the eliment(s)..
When running - the eliment should glow hot..
If its not - it migt need to be replaced..
Hope this helps !!
rate me good ;o)
Posted on Jul 13, 2009
  • 1122 Answers
SOURCE: kenmore model 417 94702300 stack washer dryer wont
bad lid switch-mike
Posted on Jul 30, 2009
GodBlessU
  • 3513 Answers
SOURCE: kenmore he3 dryer check lint screen flashes and
Hi
Try unplugging it or turning off the power at the breaker panel. This should reset the controls.
Weather this works or not, make sure that the whole dryer vent is clear. often we find a clog in the flexible line, or where the duct exits the house. also there are situations where the clogged duct caused a lint plug inside the dryer. Assuming you can reset the controls, you can run the dryer for a minute with the hose unhooked to see if you are venting the right amount of air.
OR
It is possible the heating element has gone out or one of the thermal disk has blown its fuse. If you turn the dryer on holding the button that is depressed when the door is closed so that the dryer will run you should be able to see if the heating element is getting hot because it should show as a red glow. If this is not happening then most more than likely the heating element has gone out. Most of the time they are fairly easy to replace.
OR
a simple thing is that When the lights are flashing, it is an error code, which indicates a problem with the door switch. Could be a loose connection there.
Thanks for contacting fixya.com
Posted on Nov 20, 2009
Where is the lint trap on the Kenmore stacked washer dryer model 110.88752794
The lint screen is located on the back wall of the dryer. (Inside of the dryer.)
Here's a link to the owner's manual that may be helpful to download and print out: Kenmore 11088752794 Manual
Aug 26, 2015 | Kenmore Washing Machines
Lint
this diagram will help you with the dryer parts
Aug 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
I got a kenmore with my rental Apartment. Can't find the place to empty Lint. Where is it?
When you open the dryer door, the lint screen should be on the bottom of the door opening, above the control panel.
Nov 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stack washer/dryer. There is
you have to go in through the front and a total of 5 screws
Aug 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer model 86870800 won't heat
thermal fuse is behind blower housing on models w/lint screen in door and on the back of the dryer on lint screen on top models.
May 24, 2009 | Kenmore 63942 Dryer
Dryer takes forever
You have a clog somewhere in the venting. Anywhere between the lint screen and the outside of the house. Use a vaccum with a crevice tool to reach behind the lint screen. Also check the flaps on the outside of the house. You can also access the machine end of the vent pipe by removing the two Phillips screws on the angled panel just below the dryer door. If you feel you need to take apart the machine further to clean behind the lint screen, write back. It's very tricky, and will take some time, but I can walk you through it.
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
