Question about McCulloch 11 HP 5700 WATT GENERATOR
How do you change the oil in a McCullough 5700 generator?
Lost owners manual
2 Suggested Answers
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Posted on Oct 26, 2010
Power board for McCullough Generator, FG5700. price & availability
Not exactly sure what you are asking..... But you can buy all the parts for these McCulloch Generators here:
http://www.generatorguru.com/mcculloch
Nov 27, 2016 | Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
I am looking for an owners manual for a Coleman Powermate generator model PMO645250
Powermate doesn't have an owners manual listed for the PM0645250 on their website.
Since wintertime is a good candidate for power failures I would recommend using a good synthetic 5w-30 oil as it is a good year around oil. This would make starting much easier during the cold weather
Oct 20, 2014 | Coleman Electrical Supplies
I changed the oil four times and its still milky
If your oil is milky you are getting moisture in the crankcase. Does this unit set outside? make sure your crankcase vent is clear.
Oct 29, 2012 | Ridgid Generator. 5700 Watt Yamaha 301cc...
Lost the owners manual and need to know what type of oil it takes.
any good 30 weight will do fine. If yuo run it a great deal like I do mine I put a little STP type of lube in with the oil to help it out there. Also change the oil about every 50 hours so you dont get oil break down
Best of luck
Tom
Also could you take a second to rate us, this lets us know if we are giving you a good product
Sep 11, 2011 | Porter Cable 5,500 Watt Portable Generator...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
Metal to metal
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Wht weight oil does a 5700 take?
allot the generators take 30 weight but thats a guss in the winter i had go with light weight.
i am on my second colman i lived woods for years with no electrci other generator 30 weight is heavy stops less wear tear on the insides. But winter time comes i had go lighter becuse oil was like malassas. And then i could not pull it to start it was so thick and heavy the oil in winter
go there web site look up ore try 1800 number for them to get
Jul 28, 2009 | Electrical Supplies
McCulloch 11 HP 5700 WATT GENERATOR Logo
115 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
