Question about Electrolux EW1000i Front Load Washer
Replace drum bearing electrolux ew10001
What is the best proceedure for replacing the bearing
  • Ewm01 Feb 22, 2009
    rear bearing broken up. Can I just replace this part or is there anther bearing at the back of this that needs changing as well
Electrolux EIFLS60JIW Recently and only during spin cycle a slight (for light clothing) to loud (for heavy items like towels) swishing/grinding-like sound has begun. Wash cycle is fine.
hi sounds like drum bearings are going,trouble is the drums are heat welded ,and you have to buy the whole drum,at great expence,thanks.
Oct 20, 2017 | Electrolux Washing Machines
Repair manual for 7kg eco wash system ewf1074?
Replacing the bearings is a comprehensive job and requires expertise and a lot of time.
First of all should estimate which parts should be replaced.
These are certainly the following parts: "Ball bearing - 25x52x15",
"Ball bearing - 30x62x16", Seal of drum shaft - 35-62 and besides them should be reviewed the state of drum shaft.
After a thorough review, you should estimate whether the repair cost or cheaper to buy a new washing machine.
First of all, I recommend that you look the tutorials on the following links:
How to Replace Washing Machine Bearings
http://www.how-to-repair.com/help/how-to-change-bearings-on-a-washing-machine-2-of-4
Dado
May 03, 2015 | Electrolux Washing Machines
Youtube
Something's stuck or the motor has something (a bearing, a regulator circuit, an idle wheel) bad; take it apart, test the cap out of circuit if it's old enough, and spin the mounts to find the fouled bearing (and replace that.)
Aug 04, 2014 | Electrolux Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing support.to repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at searspartsdirect.com, repairclinic.com, apdepot.com, partselect.com, or apwagner.com
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya http://www.youtube.com/user/RepairClinic?v=67hOqSFnX8g&feature=pyv&ad=9033434261&kw=drum%20bearing
Good luck,i hope ya find it very simple to replace that bearing,
GENE
Jan 31, 2012 | Washing Machines
Drum is leaking in our Frigidaire GLTF1670ASo Washing Machine. Is it worth fixing a 9 year old washer with this problem, I am thinking of buying a new washer. Please advise.
With nine years your machine reached an age that I consider close to end-of-life. Frigidaire / Electrolux boasts 25 years of warranty to some parts, but don't count on it. They'll enforce handling by an authorized service partner, upfront payment of several hundred dollars and eventually refuse refund due to too hard water in your area or they'll blame you of using unsuited detergents, all after two months of processing.
Leaking drums for these machines are quite common as they put together unsuited metals, in this case an aluminum extrusion spider in the back of the inner drum and steel parts elsewhere. Corrosion and leaking is pre-programmed.
Jan 01, 2011 | Frigidaire GLTF1670A Front Load Washer
Our Electrolux washing machine of model Aquashower 800 , spinner not working properly. Drum seams to be shaking and gives sound of friction.
if the noise your describing is a grinding rumbling sound when you turn the drum it is likely the main drum bearing have failed. you can usually detect play in the bearing by lifting the drum and seeing what movement there is compared to door seal area .1mm is the maximum 2mm would give 6mths to 12mths 6mm failure imminent.
Nov 20, 2010 | Electrolux Washing Machines
How can I change the belt?
you need to open the back up and look first study then remove it
Jun 10, 2009 | Electrolux EW1000i Front Load Washer
The drum has started making a noise an appears to be free-er than usual
Remove top cover and look at outer drum, if it is plastic, then it is a complete stripdown of m/c, not recommended unless you really know what you are doing.
If it is a metal outer drum, then it can be done from rear of washer, without too much hassle.
If you are in the u/k, and you need spares, then go to,
www.seviceforce.co.uk
Plz rate my solution.
Tghanks.
Nov 08, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Very noisy drum
To replace the bearings, you need to replace the whole backside of the outertub. Pretty difficult!
Aug 26, 2007 | Electrolux EW1000i Front Load Washer
Electrolux EW1000i Front Load Washer Logo
270 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
