Error E0000004-0101 for canon CLC 5151 copier
MediaMan85
  • 163 Answers
SOURCE: Canon color laser copier
E020 is a toner feed problem to the developer. First, check for broken gears or missing teeth on all the developers. That is usually the cause.
Posted on Nov 06, 2007
muleskinner2
  • 270 Answers
SOURCE: Error Message E020, 0400 for canon CLC 1120 Color copier
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Posted on Nov 14, 2007
checkitright
  • 1362 Answers
SOURCE: error code E000001-0003 on Canon CLC 3200
E001 on a canon is a fuser problem. check to see if the fuseer lamps come on, if yes then the problem is a Thermistor (controls the temperature of the rollers) change.
Posted on Jul 18, 2008
  • 4 Answers
SOURCE: Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
Posted on May 06, 2009
SOURCE: erorr code E061
hola, lamentablemente no tengo respuesta sino mas consultas mi canon Colc 1120 me marca E061 0031
Posted on Jun 09, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Intermittant e 003 on a canon clc 5151
hello Mike,
this could be a problem of an unstable AC supply to the machine which can contribute to abnormal Heater Supply and indicate E003 ,check also the ac wall socket it may be loose Check also the connection/plug jacks between the machine chassis and fusing unit the contact is bad or maybe loose .Check also the AC driver pc board. hope this will help.This also happens when the machine is connected to a GENSET .We do need a 1.5kw AVR unit.to stabilized the AC supply.
Jun 24, 2009 | Canon Office Equipment & Supplies
I am looking for the Canon CLC 4000 service manual that I can download.
You might try www.justmanuals.com.It is a pay site but they seem to have everything.Good Luck
Apr 30, 2009 | Canon CLC 4000 Copier
Error code E350-0000 on canon clc 1000
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
52 people viewed this question
k24674
jasbo
jasbo
