Question about Compaq Presario 5BW284 (202493-003) PC Desktop
I can't remove cover to Compaq Presario to add memory.
Please supply a solution to removing cover . Thank you
    President:
  • 2,992 Answers
Turn the computer around so you are looking at the back. There is a white plastic latch on the right side near the top. Press the latch down and slide the right side (actually the machine's left, but you're looking at it from behind, remember?) panel back toward you. Then you can lift it off the machine. There may be a screw in the top of the panel above the latch, so check for that if the panel won't slide. Compaq doesn't put that screw in at the factory, but someone else may have. Once the side cover is off you will have clear access to the system board.
Posted on Jan 18, 2009
Compaq Presario CQ50-215NR The computer has a beeping sound like a car alarm. while to Operrating system is running. It wont stop beeping
Hello.
The most common reason for this problem is memory. They could be slightly loose or faulty.
Disconnect all cables. Flip over the laptop and unlock and remove the battery.
Remove the memory cover. Remove and reinsert (on a slant) the memory module(s). Replace cover and battery.
Power on again.
If the problem persists, a memory module could be faulty. Follow the above instructions but test one module at a time.
Hope this helps.
Nov 08, 2011 | Compaq Presario CQ50-215NR Notebook
MY 5 ,MONTH OLS COMPAQ PRESARIO CQ60 IS NOT TURNING ON
Check to see if you are getting power from your power supply to charge your battery if you are most likely it was dropped or was jolted take back covers off memory cover make sure memory sticks are in proper seat also check plugs that go to modem hard drive etc it may be as simple as that if not call compaq it should be under warranty you can remove drive if your concerned about privacy good luck let me know if this helps!
Sep 19, 2010 | Compaq Presario CQ60-220US PC Laptop
I want to add more memory and I need to know where the two available slots are and how to add more memorey to my presario v2000
the maximum memory you can add for your notebook is upto 1024MB DDR SDRAM (1 x 1024MB). I will provide you the manual where you find the instructions to remove and replace the memory modules.
here is the manual :
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=500508&lc=en&cc=us&dlc=en&lang=en&cc=us
Open the above weblink and click on Compaq Presario V2000 Notebook PC , HP Pavilion dv1000 Notebook PC , HP Compaq nx4800 Notebook PC - Maintenance and Service Guide.
Then in the pdf opened refer to page 121 ie chapter 5-12
Jun 14, 2010 | HP Compaq Presario V2000 Notebook
I own a Compaq Presario S5000V Desktop. I removed
Hi!
What you need is a pc2100 266Mhz memory card..where o buy this?
Just click the link to order from their sites.
http://www.memory-up.com/Memory/CompaqPresarioS500013970.html
Much appreciated if you rate this help..thanks!
May 25, 2010 | Compaq Computers & Internet
Can i add more ram to my presario f700 it still like it came and only has 512ram
yes u can but it must be done by removing back cover and removing the ram strip the best advice i can give u is go find a book on how to do this or do a search on how to do this...gl
Dec 09, 2009 | Compaq Presario 700 470024-192 Notebook
Opening the Case
Go to Compaq website for support. They explain everything.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=en&cc=us&product=374513
Hank
Jun 26, 2009 | Compaq Presario 5000 PC Desktop
I want to upgrade Compaq Presario SR5410F with Video card GE FORCE 8600GT, 512 mb. What are the requirements of DDR Memory (Presently 1GIG AND Power Supply 200Watts). Please explain what to add and take...
To install the 8600GT, turn off your computer, unplug the power cable going to your power supply, remove the side panel of your case, remove the current video card and firmly push the 8600GT into your PCI-Express x16 slot. Now plug in your monitor to the video card’s ports, close up your case, plug in your power cable, and turn on your machine. In BIOS turn off the built-in video and enable the PCIe slot for use. Restart. Insert the included installation CD and follow the onscreen instructions. The power supply is small but should work as long as you have not added other items. The memory is adequate and does not matter as far as adding a video card is concerned. Some games may require more memory, however.
Oct 20, 2008 | Compaq Computers & Internet
Install memory
Use the following steps to remove a memory or continuity module:
Turn off the computer.
Windows 98 or 2000: Click Start , Shut Down , and then Shut Down
Windows XP: Start and then Turn Off .
Unplug the AC adapter, if present, and remove the battery.
From the bottom of the computer, remove the screw holding the RAM cover, and remove the cover.
Remove the board by pulling it away from the connector at a
45-degree angle.
Align the keyed (notched) edge of the board with the keyed area in the expansion slot. Insert the board into the slot at a 45-degree angle until it is seated.
Push the front edge of the board down until the retention clips snap into place. Then replace the cover
Aug 25, 2008 | Compaq Presario Notebook
Compaq Presario 1000
I have a Presario X1050, not sure if they are similar. Remove the screws from the bottom, carefully remove the keyboard with a small flat head screwdriver. You'll find many screws hidden by small plastic covers and rubber feet that will all need to be removed with the screwdriver. You may have to remove the display to get inside the laptop. Ultimately though, the power supply is actually external included on the power cable.
Jul 01, 2008 | Compaq Presario Notebook
Memory card
They don't sell "memory cards" for computers. However they do sell RAM(aka:memory) chips. The type of RAM you are looking for is DDR-333. It's up to you on how much you want to add.
Feb 21, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
146 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
