Question about MSI 865G Neo2-PLS Motherboard
I need a enlarged photo of the mother board (with the jumpers in their correct places). I tirm my computer on and it will boot the HDD but won't display anything on the monitor. And I've already tried using Both (several of each) AGP & PCI video cards
  • heero6x6x6 Jan 18, 2009
    Same problem here but with an IBM server.
    President:
  • 2,692 Answers
Download the manual and it will tell you where things go.  Copy the picture from the book and save elsewhere with a name.  Open the file and enlarge it on the screen.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1∏_no=151
Posted on Jan 19, 2009
Pc won't boot up
pls check ram
fix it other slot
Dec 06, 2013 | Computers & Internet
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
We are trying to install our old WD2500 into our new computer. When we start the computer it won't move past the "starting Windows" screen. We think we need to change some jumper settings but...
In printed circuit board you see "CS" "master" "Slave"
I recommend place the jumper in "master"
Use an individual cable to connect HDD, (One cable for each HDD)
Don`t connect DVD or other Hard disk HDD
Turn on the PC
Enter to setup and check if show the HDD as master
If the PC can enter to Windows
Turn off, reconnect DVD and restart
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Computers & Internet
Hi, i have an advent t9408 thay i bought off a friend with now hdd or ram so iv added 2 gb ram and a spare hdd i had, now it will not boot at all not even to the bios option screen, i managed to get it to...
First read articles on "ESD".
Link:
http://www.computerhope.com/esd.htm
Look for any warnings or post messages during boot sequence
1. Verify the RAM are the correct modules for your computer.
2. If the RAM is correct then remove 1 stick of RAM
3. Check the jumper settings on the HDD to verify Master, Slave, or Cable Select.
4. Remove the hard drive and verify the system will post.
5. Reinstall the HDD and boot to Bios and verify all devces are detected.
6. You might reset the Bios with the J2,3 to the J1,2 jumper.on the mother board.
Troublshooting is a process of elimination. Start barebones and work your way up!
May 14, 2011 | Computers & Internet
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
I took out my old hdd, and put a new one in with double the GBs.....but now when I turn on my PC, all I get is a blank screen? Won't let me load the OS....
First set your harddisk as master which has operating system.
And set slave as your new added hdd.
You can ser master and slave with jumper settings.
Read diagram on HDD.
Then check .
Also check in bios that your first boot device is your hdd which has os.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Dell Dimension™ B110 PC Desktop
A8n32-SLi Deluxe - Will not boot
your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
Nov 15, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Mar 02, 2008 | Intel Motherboard
MSI 865G Neo2-PLS Motherboard Logo
49 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
