Question about X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
How do you remove the on screen display?
Hi All, I have just bought a new computer and it came with a widescreen LCD. I thought I would use my old 19" AOC LM929 monitor for my CCTV cameras at home as the screen is too good to dump. I have used a Grand vision 2000 so convert the CCTV signal to SVGA? and the monitor shows an on screen message saying "input not supported". If I turn on the screen with my finger holding down the menu and power button the the box says "OSD locked". This then clears and I can use the monitor without the "input not supported" box floating round the screen. My problem is when the CCTV switcher changes to another camera the monitor looses sync and I have to switch the monitor off and start up with the menu button pressed all over again. Is there a way I can disable the error messages permanently...possibly pressing the buttons in a certain way to achieve this? Many thanks Confused!!
  • 476 Answers
Try changing the resolution of your screen,Misterdj
Posted on Aug 12, 2009
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Posted on Jul 29, 2007
2 Suggested Answers
6ya staff
SOURCE:
Verne Koti
  • 476 Answers
SOURCE: osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  3. Click CONTROL PANEL.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Microtek C783 Monitor flickers when turned on
Hi there. Try to remove and reseat your video card first... maybe there's nothing wrong with it actually...
But if you check the on-screen display, like the brightness controls in your lcd monitor blinking... then you need to have it repaired or replaced.
Hope I gave you an Idea.. ^_^
Jun 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Screen Resolution Error Message
go to control panel look up display adjust it ok;
Apr 30, 2010 | Envision 19" Widescreen Flat Panel LCD...
No picture - only "Adjusting" message flashing/floating on screen
your LCD panel is fried!! those flat screens are notorious for that
Jan 14, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Screen goes black with power on. It also flickers and power flickers. Does both randomly. New computer. All new drivers. Windows 7. Video card and monitor set with same display settings.
This sounds like a power issue. Check the power cord going to the monitor. Make sure it is fully plugged in. Make sure the receptacle is good and the wiring at that receptacle is tight and secure. Try another receptacle to be sure. Make sure the cord going from the computer to the monitor is secure and tight. You say this is a new computer. If so, then take it back where you bought it if you cannot find the problem.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
My samsung 19 widescreen got white screen after 2 years can I fix this some how? / Johan
Hi! using analog it seems to work for now but sometimes it blinkes white on the screen,it seems to work better when I have had the screen on, for some hours then it seems to work fine.. But I dont know for how long..
samsung 19 wide.
/ Johan
Oct 21, 2009 | Samsung T190 19" Widescreen LCD Monitor
No XP driver for Hannspree New york 19 inch monitor
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Michael
Nov 16, 2008 | Hannspree HANNS-G 19" Widescreen Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
New 19" flat screen monitor only shows analog on the screen
finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
May 12, 2008 | Gateway FPD2275W LCD Monitor
what you may need to do is find an accepted screen resolution, as your screen is 19" widescreen and your notebook will be set for a normal monitor display, so either try the auto button on the screen or look at the properties of your graphics card om the notebook to find supported screen resolutions for extended displays.
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
218 people viewed this question
Top X-10 Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a X-10 Computer and Internet Expert? Answer questions, earn points and help others
