Question about E-Machines T6420 PC Desktop
Speakers are plugged in correctly, lights on but still no sound
    Novelist:
  • 176 Answers
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Posted on Jan 18, 2009
I just set up my water dancing speakers... one of them doesn't emit any sound. Lights and water work...just no sound. Is this normal?
no it is not normal. Did you plug in the 3.5 mm plug into the headphone or speaker out port ? The Usb cable just powers the speakers. Check computer has both left and right speakers volume set correctly . Check the speaker icon right click on it . Check
Mixer and volume control .
Dec 18, 2016 | Audio Players & Recorders
I just bought a speaker for my computer but i can't hear sound from two of speakers ! how can i solve it ?
if your sound is not working you can check that the plugs are in the computer correctly usally there are green and pink ends on computer speakers green indicating goes in the green slot and pink in the pink some people often gets confused and there are sometimes on new modles a blue slot that can look green in low light i would suggest checking they are plugged in correctly to the computer preferably in the back and not the front if the front option is avalible and check the appropriate drivers are installed on the computer to use the speakers
Jan 19, 2012 | Logitech X-530 Computer Speakers
Speakers not working
Check the easy stuff first: make sure the volume is at a reasonable level and play sounds from multiple sources like pandora, youtube, a local mp3 etc to make sure issue is consistent.
Next make sure the one or more wires are plugged into the correct ports. Or at the very least the green wire is plugged into the green plug on the computer (unless they're USB speakers?).
You could always look at the sound settings of Windows and see (if your sound card has multiple plugs) if the plugs and assigned different functions (base speaker versus microphone/headphone etc.). Hope this helps!
Jun 03, 2010 | Logitech X-530 Computer Speakers
Bx1121 no sound coming from speakers. hooked up and light is own
If the light comes on , this just means its getting power , make sure it is plugged in correctly to PC , also pluged correctly in right place's , also make sure your sound card has latest drivers.
Thanks
Dec 27, 2009 | Audio Players & Recorders
Speakers and controls are working but sound barely comes out.
Check the back of the computer. Typically this caused when the connection is loose or the speakers are plugged in to the wrong jack. The correct jack on a Dell is usually a light green color. The Microphone is pink, etc.
Jul 15, 2009 | Dell A215 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
E-Machines T6420 PC Desktop Logo
128 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
