Electrolux fex831fs1 stackable washer is not agitating during wash cycle
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 30 Answers
SOURCE: NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Posted on Sep 03, 2008
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
MrJuanDerful
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating. The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
  1. Putty knife
  2. Nut driver - I used a multi-purpose screwdriver without any heads attached.
Procedure:
  1. Unplug washer from the electrical outlet for safety
  2. Release two spring clips holding the front panel on: Insert a putty knife 5" in from the side between the top and the front panel. Pull the front panel forwards.
  3. Unscrew 2 screws holding the top down.
  4. Lift top - it's somewhat hinged in the rear with three tabs inserted in control panel.
  5. The little red tab at the end of the lid switch should be between the lip of the opening and the top; not sitting on top of the lip as mine was.  It's thin enough steel to push it with your bare hands.
  6. Make sure when the lid closes it actually causes the switch to turn on. You should hear a click.
  7. Put everthing back together. Plug washer back in. Put your tools away.
  8. Voilà. Done. Easy.  Even a woman or a ****** could do it.
Posted on Apr 26, 2009
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
I just got a used Whirlpool model # LTE5243DQ6 24" stackable washer and dryer and the top part of the Agitator comes off during the spin cycle
Should be a plastic ring once you seat it ontop than push down the ring to lock in...now it should not come loose.
Feb 17, 2015 | Whirlpool Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
