Question about Pioneer VSX-60
Why does pioneer vsx60 receiver keeps turning down volume
Gradually turns down volume
SOURCE: volume control keeps going up and down when I turn down the volum
Volume Switch (Encoder) needs to be replaced professionally. Desolder the old one properly, and insert/solder the new part. Problem solved. Order part from here:
http://parts.pioneerelectronics.com/model.asp?modelNum=VSXD498
Part number asx7004
Posted on Mar 24, 2009
SOURCE: Pioneer receiver shuts off
This might not be any help to someone else, but I fixed the problem by double checking all the speaker wire connections - on the speakers and behind the receiver. A couple banana plugs felt loose and I discovered that one connection on one speaker was out completely. Suppose I should have seen that sooner, but as soon as I ensured all the wires were where they were supposed to be, I encountered no more problems.
If your Pioneer receiver is shutting off on you, double check all your connections!
Posted on Jun 20, 2009
  • 128 Answers
SOURCE: Receiver shuts off as volume is turned up beyond
try connecting only 1 speaker at a time. try it on each of the binding posts (connection terminals), crank it up to locate which one of the speaker terminals is overloading the amplifier.
Then connect a different speaker to that terminal to see if it still overloads. This should determine if its the speaker that is overloading that particular terminal or if something is wrong with the amplifier.
Just for fun make sure that the cables you are using don't have any fraying and that none of the speaker binding posts have any loose strands of wire possibly grounding out to the chassis of the receiver.
Posted on Dec 30, 2009
  • 88 Answers
SOURCE: my pioneer vsx-519V-k amp keeps turning off
check audio ic & component like resistors & capacitors. good luck!
Posted on Apr 26, 2010
  • 11 Answers
SOURCE: Receiver shuts down when setting volume above certain range.
What ohm speakers are you using? this receiver doesnt work very well with speakers that have an ohm rating below 6
Posted on May 17, 2010
I got a 3.5mm audio splitter to play my phone on my pioneer vsx-522k no sound what's up
Make sure that the volume on your phone is not turned down all the way. You should turn the volume up more than probably half though otherwise you may over-drive the amp in the receiver causing it to shut down
Aug 06, 2015 | Pioneer Audio Players & Recorders
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
VSX-1122 Pioneer Receiver keeps turning off randomly
Sounds like one or more of your speakers are bad.
Jun 04, 2013 | Audio Players & Recorders
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
My deck keeps turn the volume to zero, by itself deh-2100ib
You may have a bad volume down switch. If so, it needs to be replaced.
May 03, 2011 | Pioneer DEH-2100 CD Player
HOW SET TIME TO PIONEER DEH 3450?
turn the unit off. hold the audio/function button until display changes. turn volume knob until clock is displayed. press up/down to change hour then right/left to go to minute then up/down to change. press audio/function to exit. turn back on.
Jun 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
Apr 26, 2010 | Pioneer VSX-518-K Receiver
Overheating and shutting off
Most commonly there could be a place where wires are touching from + and minus, check all wiring to the speakers. Extra speakers would create too much load, disconnect all the speakers. Check the wires and speakers by hooking one speaker at a time back up. Of course you must turn the receiver off every time you make any changes there. Add one speaker at a time.
If it's overheating it will shut off because its likely that you are asking for more then the amp can deliver. It's protecting itself. Try turning it down and gradually increasing the volume until you find the level below shutdown. If that fixes it that's all it can deliver.
Mar 30, 2010 | Pioneer VSX-D711 Receiver
Volume control keeps going up and down when I turn down the volum
Part number asx7004
Dec 04, 2008 | Pioneer VSX-D498 Receiver
Pioneer VSX-60 Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
