Question about RCA RT2300 System
Rt2300r problems When i turn it on it clicks on then turns off, I have check all the fuses and tried another power source what is my problem
  • nexgen May 11, 2010
    hi i'm having a lot of trouble with fixing my receiver...it turns on fine untill you push a button...then the display blinks a few times n then goes into standby..i'm not sure if im disconnecting and reconnecting the right connections..could you post some visual aids if possible or explain it better because i'm just a begginer..thx a lot
  • 463 Answers
This receiver is infamous for loose connections inside of the unit due to corrosion, heat, cold or age. UNPLUG the unit from 120VAC, then open case. Disconnect and reconnect the connector from motherboard that goes to the thermister (heat sensor) on the big 120VAC transformer. It's right there on the top of the transformer, not hard to find. Then, disconnect and reconnect the smaller low power connectors which are located on the motherboard just to the right (if the front of the receiver is facing your belly) of the big 120VAC transformer. This may just fix your problem. Wiggling and disconnecting/connecting other connectors within this unit may cure a multitude of other symptoms, too...Just make sure and disconnect the unit from the mains and, as always, stay away from those large capacitors no matter what equipment you're messing with.
Posted on Sep 14, 2007
    New Friend:
  • 129 Answers
One or more of the audio output integrated circuits its bad needs to be replaced by a technician
Posted on Jun 24, 2007
SOURCE:
Receiver turns on for 2 seconds and then turns off itself, tried on different power sources but problem persists.
Short circuited component/s at its audio output stage circuit. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Yamaha RX-V757 Receiver
Truck wont start
If you have no fuel pressure at the engine when key is on, the pump is not coming on. Check fuel pump fuse, check fuel pump relay (relay should click when key turned to on-put finger lightly on it and feel for click when someone turns key to on). If no click, signal from computer may be lost, ground for relay may be lost, or relay may be bad. If it clicks, wiring from relay to pump may have failed, or the relay's main power source may not be there at relay-find the fuse link or maxi-fuse that powers that relay. One terminal at relay should be hot at all times-can check for that with a test light.
If pump is working and you do have fuel pressure, you will need to check injector circuit. Post back if questions, or need further help.
May 25, 2013 | 1992 Dodge Dakota
Will not turn on
Be sure all boxes are on, try turning on all power sources Check power strip that it didn't shut itself off. if still not check for any inline fuses that may have blown ( Blown fuses will not make contact from one end to the other. look closely
Mar 04, 2013 | Cars & Trucks
My turn signals went out and horn and i am trying to see if its a fuse
the first you can do is to check fuse! secondly is to check relay if theres no clicking sound ofcourse the power source from the battery, battery ground, body ground, ignition switch, horn switch, steering column switch, these are all the posible cause of not functioning.
Nov 21, 2012 | 1986 Mercedes-Benz 190
I have a 98 passport when i try to canrk it. It doesn't turn over it just makes a quite clicking noise for a second or two i have power tried to boost it just to be sure. I also have checked the fuses
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:5
Aug 11, 2011 | 1998 Honda Passport
I have a 1998 honda crv and the radio show err 3. the dealer gave me the 5 digit code to type in after i turn on the radio and it doesn't seem to work.
Check the fuses first. IF the fuses are good check the power TO the radio. There is sometimes a fuse within the positive lead to the radio, . If that fuse is good, try to provide a seperate power source to the radio to power it up. e.g. a battery charger on 4-6 amps is a good way to get power to the system. NEVER power the computer with an outside power source, as the amps will destroy it. The problem COULD also be the computer, although this problem is rare, it CAN happen.
Mar 21, 2010 | 1998 Honda CR-V
My 07 Odyssey is not starting in today's cold. There's a clicking sound when I turn the key. Battery is fine. Owners manual indicates it may be a blown fuse, but diagram isn't very helpful in narrowing...
If you are getting a clicking sound, then the starter is not getting enough power. There are three major things that must work in order for a starter to work. A good power source with good connections, a good starter solenoid (puts direct battery power to the starter motor when you turn the ignition to start), and a good starter motor. Usually a clicking sound indicates a fault in the first two items mentioned. If it were a blown fuse, you would get absolutely nothing when you turned the ignition key.
Jan 10, 2010 | 2007 Honda Odyssey
2006 Jeep Wrangler won't start
First, make sure you can turn the engine by hand. If you can't then the starter can't turn it either. Have someone else turn the key and look for the source of the click...may be a relay. Go over the starting circuit with a volt meter. Check for power at the starter main terminal and then with the key turned to "start" check for power at the trigger terminal on the starter. Check battery voltage and check relay operation.
You have a neutral safety switch on the transmission if its an automatic and a clutch switch if it's a stick. Check them as well. Make sure battery grounding on fender and block are also clean and secure.
Oct 01, 2009 | 2006 Jeep Wrangler
No power no led's
check there is a problem with SMPS and fuse/power socket problem thank u
May 24, 2009 | Spectroniq PLTV3250 32 in. LCD TV
RCA RT2300 System Logo
275 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
