Question about Husqvarna Chain Saw 20" Bar
When cutting, as it progresses, the cut curves to the rught automatically.
The bar appears straight and I recently sharpened the blade, though I'm new at that but tried to follow instructions. When sharpening, do I push the sharpener from the outside edge or the top edge right over the chain?
  • 6 Answers
Sharpening a chainsaw is an art. I wokred in the logging industry for 20 years before I was shown how to truly sharpen one well!
It appears that your problem has one of two causes.
1. Sorry, but you may not have filed the chain correctly, a common problem for newbies and some veterans. Ensure that all cutters are filed at the same angle (save your old chain and buy a new one for a quick solution). The file should be worked from the back of the tooth to the point ONLY. The file should be stroked at 90 degrees to the bar and parallel to the line that is inscribed on the tooth (if a line does in fact exist). Each raker should also be the same height - get a raker gauge from your chainsaw shop. If the rakers on one side of the chain are lower than the other side and/or the cutters are filed at significantly different angles on one side than the other the saw will cut in a curve.
If you look at the cutter from the side each one will show a quarter moon filing "circle" and both sides of the chain MUST be equal or close to equal. If one side has a moon and the other does not the saw will cut in a curve so severly it will bind in the cut.
2. A worn bar that is higher on one side of the chain groove than the other will also cause problems - a new bar is the only long term solution for this. The unequal height is caused by incorrect filing of the chain and long term use of the bar with this condition.
If the bar is in good condition and the rakers and cutters are filed properly you will not have to push on the saw to make it cut - it will pull itself through the wood. Indeed, before you buy a bigger saw to cut faster you should ensure correct filing - you may amaze yourself and your buddies!
I am a Certified Faller in the Province of British Columbia, Canada if you are wondering about my credentials.
Good Luck and Safe Cutting!
Doug Hough
Parson, B.C.
Posted on Jan 25, 2009
Ihave a Husquvarna chainsaw I just sharpened but when it cuts into the log it curves to the right and jams halfway through the log.
first flip the bar over that will show if the bar is bent if still cuts wrong in the same direction then the bar is good and you didn't sharpen the chain the right way
Aug 09, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Saw cut is not straight. It curves until it freezes the chain.
Hi, sounds like the blades on the chain are either blunt and need sharpening, or they have been sharpened at the wrong angle.
Hope this helps
Sep 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw isn't cutting straight
The odds of a bent a bar approach winning the lottery, while possible it is not likely! ALL the teeth must be of equal and opposite angles. I think a new or professionally sharpened chain will cut true.
Pretty good quick video. There are many that are not worth watching.
http://www.5min.com/Video/Tree-Cutting-Safety-Chainsaw-Sharpening-15094965
By Oregon and very comprehensive. I suggest you read everything that looks remotely connected.
http://www.oregonchain.com/pro/service/faq.htm
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 25, 2010 | Husqvarna Forest & Garden #966906636 445...
All the chains i cut cut to the right not straight through the log. The bar is new.
Pay a professional to sharpen one chain. If that cuts straight examine your sharpening procedure or the individual that does the sharpening.
Lou
If not please post back below.
Jan 26, 2010 | Oregon Scientific Oregon Bench-Mount...
Machine cuts on a curve, not straight. How fix it ?
When my Pioneer did this after many years of service I found a wire edge had developed. A flat file at 45° to the bar around the perimeter of both sides solved my problem. I still have the bar. it cuts true. HTH
Lou
Nov 01, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
1,511 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
