Question about Frigidaire GLTF1670A Front Load Washer
What is the capacity of a Frigidaire Gallery model GLTF1670ASO
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Frigidaire Model # GLTF1670ASO
check you drain / drain pump... slow drain will cause a long time wash
Posted on Aug 13, 2008
geemarie
  • 876 Answers
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
  • 10 Answers
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
aborcass
  • 2651 Answers
SOURCE: A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Posted on Feb 14, 2009
What is the capacity of Frigidaire washer GLTF1670ASO?
dont you have your frigadaire user manual
http://www.retrevo.com/samples/Frigidaire-Washer-manuals.html
tell us if you cant find the answer
most problems are caused
by user who dont defrost totally for like 4 days
then clean and restart
and failt too clean the eveporator trays and tubes {not for users for a tech}
if your not sure always ask for professional help
however cleaning the pipes and tubes and V shaped water guides
esp behind the back of the freezer cab
esp if the botton freezes and the whole cab doest
then the blast fan may have failed
Mar 05, 2015 | Frigidaire Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
What is the capacity of the Frigidaire Gallery model FWT449GFS0? It is approximately 13 years old.
The capacity of the Fridigaire FWT449GFS0 is 2.7 cubic feet. I got this info from calling the Frigidaire toll-free help line. It is NOT part of the model number!
Jun 14, 2012 | Frigidaire Washing Machines
My frigidaire gallery washing machine model GLTF1670ASO will not unlock the door. Removing and plugging again the electrical connectors did not help. I suspect timer is shot. Any other things I should look...
I would say your door lock is faulty, much more common than timers. Unfortunately, you need to break the door catch to open door. If you take off the top, then use a flat head screwdriver (oh, and turn power off), and pry at door switch. Replace the door catch (part#131763310) and the door lock assembly (131763202) and that should fix your problem.
Apr 07, 2010 | Frigidaire Washing Machines
What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
May 27, 2009 | Frigidaire Washing Machines
Feb 14, 2009 | Frigidaire Washing Machines
Aug 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Need new washer to stack on my dryer!
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
203 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
