Question about Jenn-Air Kitchen Ranges
JENN AIR SVD48600WC FAN COMES ON
OVEN FAN COMES ON WHEN HEAT IS ON
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
SOURCE: Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Posted on Jun 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: Jenn Air W256B error code F8
Hi, F8 on later model jenn-air ranges/wall ovens indicates an issue with the meat probe, usually the resepticle. The fault is sensing a temp. at the probe above 250. Unless you actually have the meat probe inserted into the recepticle and the oven has heated above 250, then it's not likely the meat probe itself. Hence why the recepticle is likely faulty or in need of inspection/adjustment. Here's how (this may or may not work...sometimes it does though). First unplug the range or shut off the power to it. **The probe is attached on the oven liner via a nut, however you,ll need to gain access to the outer side of the liner by removing the side panel if the recepticle needs to be replaced, but hold on.** You nay only have to loosen the nut and re-tighten it to insure the recepticle has a good "ground" to chassis. there is only one wire attached to the other side (you can't see it) because the probe converts temperature to resistance in the control, that is why this "ground" is essential and can cause "faults" if not secure/sufficient. At times that's all it takes to force an F8 code. Try this first, reset the power and see if it yields a successful remedy. Hope that helps, good luck Hope that helps, good luck
Posted on Oct 03, 2009
  • 43 Answers
SOURCE: It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Posted on Oct 25, 2009
  • 969 Answers
SOURCE: jenn air jds8850aas f1-1 code and beeps when oven
http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
Jenn air microwave....
Probally the belt is broken on fan up at the top.
Mar 13, 2009 | Jenn-Air M439 Microwave Oven
Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
OVEN WILL NOT CLEAN JENN-AIR SVE47100B
It was recommended to me by your service that I call a service person. I did that. thanks.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
23 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
