Wiring diagram for a potterton room stat Prt2
2 Suggested Answers
  • 36 Answers
SOURCE: fitting room stat
take the link out and fit stat wires in its place,will work then.
Posted on Jan 31, 2010
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
Potterton wiring diagram
Look on the baxi potterton wedsite you can down load mauals for your potterton or e-mail there tech line .
Feb 10, 2012 | Heating & Cooling
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
Fitting room stat
Dec 18, 2009 | Desa International CBN30T Central Heating...
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Nov 13, 2009 | Honeywell Electronic Programmable...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
434 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
