Question about Sony Audio Players & Recorders
How do I purchase a replacement stylus VL 42G and how do I remove the old stylus and install the new on my Sony Turntable PS LX320?
SOURCE: new needle for sony ps-lx250h?
I have the same turntable and I just bought a replacement needle through the needledoctor.com. The needle is made by Audio Technica and the part number is ATN3600L.
Posted on Feb 27, 2008
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
SOURCE: Sony PS-LX300USB Turntable, one channel not working
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: I need to determine appropriate stylus replacement
any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
Posted on Sep 23, 2009
  • 5603 Answers
SOURCE: how do i replace belt on lx250h?
Not sure about yours, but some of these one lifts the rubber pad to get access to the belt through holes in the platter when you are re-installing to get the belt back on the hub it runs on. One usually has to lift the platter off to get the belt around the center hub and the motor pulley first..
You can probably find the belts online with a Google search.
Posted on Dec 10, 2009
Hook up sound to a sony ps-lx340
try a RADIO SHACK SA-155 MINI AMP at Radio Shack. I believe around $30.00. Use the amp many times.
Nov 28, 2014 | Sony Ps-lx320 / Ps-lx340 Stereo Turntable...
I just replaced the stylus on my sony PS-LX300USB turntable, but now there is a constant static on even my new records
You have either knocked the connections to the cartridge causing a loose connection, or not seated the stylus right. Or you have static build up, which can be caused by poor earthing.
Mar 12, 2014 | Sony PS-LX300USB Turntable
Need a new stylus for my turntable SONY PS-LX250H and cannot seemed to find a new one. where can I get a new one at.
Assuming it is the original ATN-3600 cartridge, a simple web search for "sony ps-lx250h replacement stylus" or "atn3600 stylus" locates some.
If the cartridge is something different you should search for that model's stylus, not one for the TT itself.
Sep 03, 2011 | Sony PS-LX250H Turntable
My turntable does not have good sound? Is it the stylus needle?
It could be, first check all connections as they can come loose. It could also be the cartridge, the only way to find out is to get a new one. If you get a cartridge and stylus, you can fit the new stylus to your old one, if that solves the problem, you have a spare cartridge in stock, if it doesn't then replace the cartridge. If that doesn't work and the connections are good, then there is a fault on the magnetic cartridge pre-amp in your amp.
Jul 14, 2011 | Sony PS-LX300USB Turntable
HOW DO WE REMOVE THE STYLUS TO REPLACE IT FROM THE SONY TURNTABLE PS LX250H? AND HOW DO YOU CHANGE THE HEAVINESS OF THE TYLUS/NEEDLE UPON RECORDS/ HEAVIER OR LIGHTER WUEIGHTED ON THE VYNILS!/? WE CAN'T...
You should be able to pull down on the front of the stylus and then pull it out from the cartridge. There is no weight adjustments on this model.
May 17, 2017 | Sony PS-LX250H Turntable
Just received our Sony PS-LX300USB turntable, but cannot get the stylus to stay on. Any suggestions on how to install the stylus?
Hold the stylus at an angle, rear up/needle down. Put the rear of the stylus in first and then push the front of the stylus up and clip into place.
Which stylus number did you use?
D.
Nov 09, 2010 | Sony PS-LX300USB Turntable
Need a stylus ND-6516
These are the two that I use the most when replacing needles. www.lpgear.com and www.needlefinder.net. The latter one has an e-mail address and they're pretty quick to get back to you.
Apr 02, 2010 | Sony PS-LX250H Turntable
Replacing the stylus
Go to esupport.sony.com and type in your turntable model, PS LX250H. The "H" is important. Available is the complete manual, and a separate publication just on removing the stylus and setting EQ. Basically, swing the protector bar down over the needle, and snap the entire (mine is beige) unit down from the tone arm, then pull forward. I'm still shopping for the replacement, frankly.
May 21, 2008 | Sony PS-LX250 Turntable
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
294 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
