Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Snowblower won't start, like no gas going thru
I have a yard machine snowblower, it was just overhauled because I left gas in it for 2 years which turned to varnish, so all the lines and the carb were clearned. I just tried it today it worked for 10-15 minutes then shut down, like it ran out of gas, but there was plenty of gas. I tried to start it again, and it started and ran for 10 seconds. Now it just keeps turning over with out starting. What am I doing wrong This has an electric starter. t has a Tecumseh engine
  • 7 Answers
SOURCE: I have a yard machine snowblower that will not start
If the engine is infact seized, then it will have to be re-built or replaced. It was probably run with very low or no oil at all. You may be able to get a short block for your engine. All you would need to do is reuse your cylinder head, flywheel, carburetor, ignition modual, recoil houseing, fuel tank, governor linkages and controlls. The engine block and all internal parts would be replaced. It is far cheaper to just replace the engine rather than re-build it unless you are able to do it yourself and save the labour cost.
Posted on Dec 12, 2008
  • 17 Answers
SOURCE: Tecumseh HM80 on coleman generator. won
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Posted on Mar 15, 2009
  • 246 Answers
SOURCE: My tecumseh 5 hp engine will start but then after
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 81 Answers
SOURCE: tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Posted on Jun 17, 2009
I started this snowblower in the summer and it worked fine...both winters I've tried to use it it won't start. The first year I had it it worked very well.
So you are saying it wont run in the cold. Will it run if you left it in the house until you wanted to use it?
Are you going thru the procedure of Choking the engine ? Is there a Primer Bulb that you have to push on this machine?
I'm just saying that engines don't like the cold to begin with, just make sure you are going thru the 'Cold Start' procedure properly.
Jan 20, 2016 | Toro Power Clear Snowblower 418ZR - 38272
When in gear right wheel drives left wheel is locked and will not move same when not engaged
Many snowblowers use pins (or bolts - see image below) that pass thru the shoulder of the rim of the tires thru a hole drilled thru the drive shaft. Removing both of the pins allows the tires to spin freely on the drive shaft and makes it much easier to push, pull and turn the snowblower. If they are not installed again, the machine will not "drive" and make clearing snow difficult to do. Installing only one will make the machine want to go in circles. Make sure you have these pins installed thru BOTH rim shoulders and drive shafts - locked in place. Other machines lock the tires in other ways - since it sounds like one side is working correctly - you should compare the two tires / rims and make them both look like the one that works properly. Good luck!
Jan 06, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
How to start the snowblower yard machine when you've tried everything to start it up correctly and it doesn't start?
How did you store it? The gas should be drained out of the carburator and tank prior to storing. If you don't do that it starts varnishing the jets closed in the carburator. So to start it, try draining all the old gas out. Take the spark plug out and put the wire back on and lay it on top of the block. Crank the engine over turn switch on if it has one, does it have spark? If it does good. If not try a new plug, if it still does not have spark you will have to pull the flywheel to see what is wrong with the points or pickup. Once you have spark established, put new fuel in tank. Spray a little WD40 into spark plug hole. Put spark plug back in and go through normal starting procedures. Good luck.
Jan 06, 2012 | Sewing Machines
MTD Yard Machine 675 series 190cc Always started now won't, does not turn over. Can pull it to start but does not start. What can we do to fix it. One year old, never had problem before. Machine...
Based on you question, this could be anything (like going to your Dr. and telling him "I'm sick"). That being said, if it just sat with gas in it, then it's likely a fuel problem (ie; plugged carburetor). These machines do not like the new Ethanol Gas and they cannot be left to sit or they'll gum up on you. An engine needs three things in order to start and run. 1. Spark 2. Fuel 3. Compression. First check your spark; if there is no spark, it'll never start. If there is spark, then I recommend a good carb cleaning. Better left to a professional if you're not familiar with this procedure. I hope this gets you started in the right direction. Best of luck to you. (You can find "how-to" videos on all these procedures by searching on YouTube)
James
Oct 15, 2011 | Mtd 22" Yard Machine Push Mower
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
574 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
