Question about Samsung SP-R4232 42 in. Plasma HDTV
Green snow now black screen
Hi 1st my I had green snow with bad picture now The picture went black but still have audio . If its the logic board . How much are they .
  • 1 more comment
  • Jay Robles Jun 29, 2007
    What else could it be
  • Jay Robles Jul 05, 2007
    Which is the logic board the middle one ?
  • dANIEL mOORE
    dANIEL mOORE Jan 16, 2014
    its the board behind the rc cable jacks that actualy prouduce dvd cable signALS
    Sergeant:
  • 279 Answers
Yes, the logic board is the middle one.
Posted on Aug 30, 2007
    President:
  • 3,130 Answers
Your problem is the logic board and can be purchased from here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BN96%2D02042A&search%5Fmodel=SPR4232 Good Luck
Posted on Jul 03, 2007
  • Larry  Dillon
    Larry Dillon Jul 05, 2007
    You will need to replace parts. I cannot fix this for you. Replace the board and hopefully there will not be too much adjustments involved. But if you do replace the logic board, and the set does not work, would not mean that the logic board was not bad.
    Scholar:
  • 77 Answers
It could be the logic but also the Y main. Probably should let a pro take a look it could be an expensive guess. Either circuit will cost you a few hundred. Good Luck
Posted on Jun 25, 2007
6ya staff
SOURCE:
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Screen went white
The white glow with no picture means that either the ribbon cable connection between the logic board and the monitor has come lose or dirty contacts, or the LCD Controller (T-CON) board (part of the LCD panel is not getting 5v or 12v depend on LCD panel from the logic board or the LCD controller board has blown fuse, see pictures here for guide (note pin on the LCD board with arrow mark is pin 1 and is the incoming DC power supply line): http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/?action=view&current=DSCF0881.jpg
You may also want to look for bad caps (bulging top) on the logic board. There should be 5vdc feeding the logic board also.
Mar 31, 2010 | Envision G918W1 Monitor
We have a Sony Bravia 40'' LCD that the screen went white and then black and won't come back on. The power button comes on but no picture. Just bought the TV in Nov 2009
the most likely the t-connector board became unplugged or failed completely (sits right behind the screen modual at the top&center) or.. the logic board has went kaput on ya...ontop of that, you are dealing with the notorious sony. try and get a replacement if under warranty. do not settle for thier refurbishing.
repairing these things i can tell you , it could be anything from a bad connection or ring cracks to completely failed parts. but only if i was in it would i know for sure. but the symptoms suggest t-connector or the logic board.
Feb 15, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Jan 13, 2010 | Philips Magnavox 42MF521D/37 Television
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Aug 22, 2009 | Sanyo Televison & Video
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
LCD TV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Dec 28, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
207 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
