Question about Kitchen Ranges
Model C880 6605 30J1 kenmore range wire diagram
2 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
Posted on Dec 07, 2007
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
How can I get a wiring diagram for part number 316436001?
The wiring diagram should be on the range that the switch is going on. That's a Frigidaire part number and they usually put the wiring diagram on back of unit. If not, you can look at the other switches and just match up and wire the same. Be careful and Good Luck
May 21, 2016 | Kenmore Kitchen Ranges
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I have a kenmore model 790.46893900 glass cooktop 0ven and i need to no where each of the 6 wires hook up exactly? they are the wires in clock and control digital display.
There is an old saying amongst Technicians. If you don't have a wiring diagram, mark every wire where it goes before you unplug them. The oven should have a wiring diagram somewhere behind one of the covers. If it doesn't, you may need to contact Kenmore or one of their Agents to see if they have a service manual detailing the wiring connections. Sorry , but I don't have any info on Kenmores. I don't think they are sold in Australia.
Sep 15, 2015 | Kenmore Kitchen Ranges
91136669891 HAS ERROR CODE F2 F3
Are you sure about this error? The 91136669891 was made by Whirlpool for the Kenmore line. The 4 character codes for these ranges are F# E# (not two Fs).
Depending on which error you are actually have see below.
If the code includes F3 then you have a problem with the oven temperature sensor (F3 E2 would be temperature too high). You need to replace the sensor. Sears Parts Direct has the sensor for $74.12: http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Range-Parts/WB21X5301/0022/364/Model-91136669891/0582/0124250?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P9040087&diagramPageId=00005&productTypeId=x&searchModelNumber=91136669891&subCompDesc=Body&brandDesc=KENMORE&modelDesc=30 . The complete diagram of the oven parts is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00005?blt=06&prst=&shdMod= . The sensor is part 253.
If the code includes F2, then double check the second code. Whirlpool has no F2 E3 error that I know of. However, F2 errors tend to be a problem with the keypad. Check the wiring connection between the keypad and the control. This should be firm. Then press Cancel. If the error persists, you need to replace the keypad. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00001?blt=06&prst=&shdMod= for the parts diagram and prices.
I hope this helps.
Nov 23, 2011 | Kenmore Kitchen Ranges
Looking for wirirng diagram to install my oven control module for Rnage model # 790.95032503.
It seems someone else was having a similar problem on a different website, and the moderators came up with the following page for a wiring diagram for your model number.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441458en.pdf
Feb 28, 2011 | Kenmore Kitchen Ranges
Unhooked 4 wires on door lock mecinasm on kenmore gas range model #66575002100 can't remember which one goes where
Here is part of the wiring diagram for that
It looks like the gray wires go to the switch either one in either end of the switch and the White and Brown go to the motor.
May 08, 2010 | Kenmore Kitchen Ranges
Circuit board replacement for a Kenmore range model # 95792000
Yes and no, if you can get it apart, it is basically placing the wires on the new board from the old one.
As long as the board was not updated and it looks exactly as the old one does, you can see where
everything goes from old too new. Do each wire one at a time with boards next to each other, or
make a diagram of all the wires,color, and where they go. If you start and forget, you will not be a happy camper. Hope this helped,and please post back with any other questions,everyone is happy to help.
Mar 26, 2009 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
