Question about Delta 36 979 10 Inch Left Tilt 1 1/2 Horsepower Contractor Saw With No Fence, 115/230 Volt 1 Phase
Need to purchase delta 36-979 dado head table insert for 10' table saw
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Posted on Dec 19, 2014
rowdy45176
  • 2176 Answers
SOURCE: A Delta 10
Found it. Follow me closely. Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number, on the next page click on the breakdown type 3, USE the numbers on the left. Next look down after the schematic comes up and under instruction manuals use the last one (EN) click on it once move your mouse and click again then go back and click on it again, it will then bring up the manual. I don't know why you have to do it that way but most of their manuals you have to. The manual is about 20-25 pages long. Let me know if you have trouble because I had a little and if I have helped answer your problem would you please rate my response accordingly and Thank you.
Posted on Jun 06, 2009
  • 236 Answers
SOURCE: I am not having much luck with blade alignment on
Check that the washers on the motor shaft are positioned properly. I believe the washers are dish shaped one should be on each side of the blade with the wide shoulder aginst the blade. Check this. Also if you go to Deltaportercable.com you can get an owners manuel for free on line. If this was helpful, please leave feedback.
Thanks, Snugglepants
Posted on Nov 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Posted on Dec 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need an instruction manual
you might try Dewaltservicenet.com and type in your model number in the middle of the page under need manual and see if you can find it there if not let me know and I will try and find one for you.
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
How do I install a dado blade? Does the inside large collar need to come off?
Because of the larger hub assembly, the collar will need to be set aside. Be sure to use a dado insert in the table and get a carbide tipped tool if you can afford it. Make shallow cuts or the work piece will grab and be thrown off of the table. Always make a test cut on similar waste to make sure that it has been set correctly. Make or buy a push stick if you don't have one already. It also make copious amounts of waste! Have fun!
Nov 10, 2010 | Dewalt DW744X 10" Portable Table Saw
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
Jun 29, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
Need dado throat insert for 113
why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Dec 11, 2009 | Hardware & Accessories
I need an instruction manual for my delta shopmaster 10'' bench saw model number TS200LS. I know very little about table saws and need to change the blade and would like to install a dado blade.
Nov 21, 2009 | Delta Saws
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Delta 36 979 10 Inch Left Tilt 1 1/2 Horsepower Contractor Saw With No Fence, 115/230 Volt 1 Phase Logo
290 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
