Question about American Standard 1/2in NPT Shower Arm Diverter - 1660.410/Choose Valve Fin
I'm trying to replace my shower head and am unable to remove the old one from the shower arm diverter, any help would be appreciated
  • 10,865 Answers
Use a crescent wrench on the shower head. If the head alone won't budge, the entire head plus arm will unscrew. Then just pick up a new arm and some teflon tape and reattach both. good luck
Posted on Jan 18, 2009
How do I change a single diverter to a 3 way diverter?
Not exactly sure what you are attempting. A quick-and relatively inexpensive way-would be to add an Alsons diverter to the shower arm. It is simply removing the shower head, adding the diverter, and reinstalling the shower head and accessory hand held shower. If you are looking for something different, there are myriad valves on the market that would allow for such change. However, changing to a new valve could get somewhat complicated. For example: you may need to increase the size of the supply lines that are feeding the shower; some diverters require a 3/4" feed.
Also, if you check the box stores, they have several shower/hand held shower kits that already have the diverter with the packaging. Again, I am not exactly sure of the end result in which you seek, but I hope this helps some.
Oct 31, 2014 | Dmm Symmons Temptrol pressure balancing...
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
Bathtub diverter not working
After you use the diverter to get the water to the shower head, you leave it alone. When you turn the water off the diverter will automatically go back to its default position of faucet.
Sep 15, 2017 | Home
Can this diverter run both the shower head and a hand held shower.
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Mar 04, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
American Standard 1/2in NPT Shower Arm Diverter - 1660.410/Choose Valve Fin Logo
155 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
